Question about Maytag MER5775Q Electric Kitchen Range
Our oven is giving us an error code of F1. It began when we the oven was preheating and when it reached the temp. it would shut off. We replaced the "brain" main component in the back of the oven after paying $150.00. It looked like it would work, then when we were using the oven it started beeping and it came back with the F1 message. We shut the power off to the stove again, and when we put the power on again, the oven is still beeping and sending us the message. The number inside the range is 8114P628-60.
  • 641 Answers
SOURCE: error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Posted on Jun 08, 2006
  • 878 Answers
SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. back.
Posted on Jun 05, 2007
  • 161 Answers
SOURCE: Maytag Gemini electric oven
Well my friend these type ovens have eyes and sensers. It could be that you left something on the sensor when you were cleaning it. That is if it is not self cleaning. Self cleaning gets real hot and could affect your appliance in some way. It shouldn't but it might.
Posted on Aug 07, 2007
SOURCE: Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
I own the magtag gemini model MER 6770 AAW serial number 14882525YB the message I am getting from the panel is F 1-2 then it beeps until I cancel then sometimes it returns beeping. Sometimes the top oven cooks fine but if I try to cook with both ovens going it goes all crazy with beeps and shuts off and sometimes won't go over 100 degrees in both ovens. I am a very handy person and if someone can tell me how and what to replace I know I could do it. The repair center said it could be $300 plus to repair. My stove is 8 years old and I paid around $1300 for it I can't afford to replace it. HELP if it is out there otherwise I guess I will have to pay to repair it still cheaper then buying a new one...
Posted on Sep 11, 2008
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
What does it mean when your Samsung flat top oven and broiler will not work and the code reads E-08
E08 Error Message on a Samsung Electric Built-in Oven:
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
Apr 14, 2015 | Samsung Kitchen Ranges
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
When my oven almost reaches the temp during preheating, an alarm sounds and I recieve an error code F 1-2... The tech support line for Maytag(now Wirlpool)had no idea what this means and advised me to...
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
never heard of an F1-2 code but they make new stuff everyday. Go to this link to get tech data: Maytag library of manuals
Aug 19, 2010 | Ovens
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
F3 & F1 Errors & oven shuts off
Concerning the F3(Open or shorted oven temperature sensor (RTD)
Concerning the F1(Stuck touch pad)
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Jun 02, 2009 | GE Ovens
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
78 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
