Question about Nikon Coolpix 4600 Digital Camera
Mine says system error 10 how do i fix it
When i turn my camera on screen says system error 10 how do i fix it
My Sanyo X1250 Digital Camera says System Error evertime I turn it on. Is there anyway I can fix this without returning it??
this is how I got mine to work, while off hit the play button the triange icon on back of camera. go to reset under the wrench icon, set the date and time and sgut it off. turn back on. fixed!!!!!!!!!!!!
Oct 18, 2010 | Sanyo Cameras
To solve an error
You could try this
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don’t let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
Feb 26, 2008 | Sony Cyber-shot DSC-T100 Digital Camera
Error message at display screen
Set both the exposure dial and the focusmode to "M" and press the shutter button. Then turn the camera off for 10 - 15 seconds. If this doesn't solve the problem, it's an electronic or mechanical error.
Jul 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
E:62:10 error
Hello!
When I turn on the camera Sony Cyber-shot digital screen display E: 62:10. Please tell me how to fix it.
Thanks
Jul 22, 2009 | Sony DSC-T30 Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 21, 2008 | Nikon COOLPIX S10 Digital Camera
Nikon 4600
Hello, Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 seconds then replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
Dec 03, 2008 | Nikon Coolpix 4600 Digital Camera
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
A210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
Dec 23, 2007 | Fuji FinePix A205 Digital Camera
HP Photosmart R725 camera error.HELP!
Smack it a couple times, gently. You have nothing to lose, AND, I swear it works!!!
Dec 20, 2007 | HP Photosmart R725 Digital Camera
Indication E:62:10
I had the same error- I tried wacking it against my leg- and now it works again!!! thank you!
Sep 28, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
