Question about Garden
Instructions re.Carb.adj. for MONDO Weed-eater
The operators Manual I have states for basic carb.settings states
""Turn Low & High speed mixture screws to the midpoint between the limiter cap stops"" The carb.on the machine does not show LIMITER CAP STOPS and I would think is adjusted as usual by backing screwws off from closed positions. I would like to know what the basic adjustment is>
Machine I/D numbers appear to be 98071N.400185-1
5 Suggested Answers
SOURCE: ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Posted on Nov 24, 2008
  • 109 Answers
SOURCE: Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Posted on Apr 22, 2009
  • 100 Answers
SOURCE: My weed eater will not start. I have rebuilt the
one is idle screw...no setting till running....one carby you will see letters L and H next to screws both thes screws are usually set all way in not tight!!! then back them out one full turn each ....that is starting position
Posted on Aug 14, 2010
  • 144 Answers
SOURCE: How do you adjust the high speed mixture screw? I
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Posted on Feb 28, 2011
Husqvarna 128LD weed eater wont start - replaced spark plug - carb - ????
If you can confirm that you have spark then you basically have a fuel delivery problem - carburetor.
If you installed a new carb you have to set it up , with the idle adjustment , and the low and high speed mixture screws. You just do not insert the carb and expect it to work.
Aug 29, 2017 | Husqvarna Garden
Runs slow
In California the new blowers have sealed mixture adjustments and you need the have your carb. mixture adjusted be a qualified shop. If your carb. HAS mixture adj., turn the high speed mixture so it runs best at high speed, then turn another 1/8 turn counter clockwise to be a little rich. Then at idle adj. the other screw till it idles best.
Apr 21, 2014 | kawasaki Krb300a Backpack Leaf Blower
My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
Weed eater starts and idles after it warms. When I accelerate it sounds like it is choking itself out or it is starved for gas then stalls.restart and it does it all over. Sometimes it stalls when i go to...
Take out carb and spray with carb cleaner through and into all portals. Blow out with air compressor.and reassemble.
Adjust idle and low and high mixture screws according for proper operation.
Aug 31, 2017 | Weedeater Set (Weedeater)
Need tool to adjust carb on a ppb 100 polan weed eater
1 1/4 turns out. Then let it warm up and adjust 1/8 turn lean, which is in, to make it run best. But that is only right if you just rebuilt it and everything inside clean and wrkn right. May have to adj in less?
May 11, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
My john deere 1600 weed trimmer starts fine cold, then runs on high speed for several minutes then dies .Then will not start.I cleaned spark plug, checked proper oil/fuel mix, cleaned air filter,tightened...
Your fuel low fuel high adj on carb arent set right. one is for idle and low running while other is for high rev. Getting these set just right is very tricky and takes some time doing it to become good,Im starting you off on a crash course,Im not gauranteeing anything but here it goes. LOcate the two fuel adj. screws on carb,if they have plastic caps on top remove them with needle nose pliers so the screws themselves are exposed. Next,I want you to take a screw driver and turn both in all the way till they stop. Now take and turn each one out counter clockwise three full revolutions. Now start it to see if theres any improvement. (Note: further adj. may be required you may have to consult an expert to have it be done for you if you cant get it).
Aug 02, 2009 | Garden
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Jul 01, 2009 | Homelite Garden
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
