Question about HP PhotoSmart C4480 All-in-One Printer InkJet
1 sheet of paper papet jamed in printer it wll not move in ether
Direction it appears to be torn and crumpled.
robbe-zappa
SOURCE: Paper completely wrinkled
I have two HP LaserJet 1300n printers and like all printers after use (or misuse) they will need PM or repair. The problem with the paper wrinkling is easy. If you have worked on printers then you can make the repair for about $8 - $20 and a couple hours. You can find the service manual at HP's website or online. It is typically a roller or the fuser film is torn. Disassemble the printer/fuser in accordance with the service manual or break out pic, clean, replace part and reassemble. For those who do not want to DIY then you can buy the entire fuser assembly on multiple sites anywhere for refurb w/core exchange to new for $70 - $150. The printers are good printers but like all mechanical devices, they will fail...it's just when and how.
Posted on Jan 28, 2007
hemantraj
  • 638 Answers
SOURCE: HP LaserJet 1300 crumples paper on top left corner
simple, the printer needs servicing as the gears which forwards the paper out from the left side r getting blocked somewhere.and the gears needs to be cleaned.
Posted on Nov 14, 2008
  • 66 Answers
SOURCE: Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Posted on Dec 18, 2008
SOURCE: paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Posted on Mar 17, 2009
  • 16 Answers
SOURCE: my hp deskjet 6988 all of a sudden has paper jams
try opening up the printer make sure nothing is stuck on that end
May be try changing the rotors on the printer...
Might be time to get it serviced i say .. seems to be more of a hard ware issue than anything else
Posted on Feb 04, 2010
Keeps saying paper jam,but no paper jam is inside
The jam indication is set because the sensor(s) detect one. This could be due to a buildup of paper dust, a small bit of a sheet that tore off and got lodged deep inside when removing a previous jam, or damage to the sensors if the jam was removed forcibly by pulling the sheets out from the wrong direction.
Dec 10, 2015 | Brother DCP-7020 All-In-One Laser Printer
How can I remove a paper jam from under the fuser bar in Brother MFC-8440?
sometimes a good long pair of tweezers helps , I use fishing forceps myself . have 4 different sizes from 2 inch to 14 inch
Oct 27, 2015 | Brother MFC-8440 All-In-One Laser Printer
I have a paper jam and I can't locate the problem. I accidently loaded the printer with paper not knowing that several sheets had been stapled together. I removed the jammed paper but it still keeps...
  1. Turn the printer off and unplug the printer from the A/C outlet.
  2. Open the printer and check the paper path for a paper jam or misfeed.
  3. When the paper appears as crumpled or waded up, carefully remove all the jammed paper.
  4. When the paper appears to be angled incorrectly, it may be misfeeding through the printer, remove the sheet of paper.
    • Remove the paper stock and reinsert the paper, make sure the paper guides are adjusted correctly.
  5. Close the printer cover(s).
  6. Plug the printer into the A/C outlet.
  7. Turn the printer back on.
  8. Resend the print job.
  9. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Dell Printer Support
Feb 26, 2014 | Dell 3110cn Laser Printer
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Hp deskjet f2280 paper jam but the catridge is not moving what to do
I downloaded the User guide from HP http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&product=3390947
It gives very simple instructions for removing the rear access door (push the door to the right and pull out). I found a torn corner of crumpled paper in there. It also warns against pulling paper out the front which can damage the print mechanism.
Feb 22, 2011 | HP DeskJet F380 All-In-One Printer
Keeps telling me to clear paper jam but I dont see one
look on the back to see if there is a removable plate that will expose the rollers. On my HPs I have to clear a paper jam when ever the paper in the tray absorbs too much moisture. A sheet gets crumpled in the rollers where you cannot see it and the back plate allows me to pull the crumpled sheet clear. That is also where the paper sensor is located.
Dec 28, 2010 | Dell 924 All-in-One InkJet Printer
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Paper feed jams, and when tray is inserted, the top sheet is pushed forward and crumpled along the front edge.
sounds like you have something obstructing your paper path,before inserting the tray check to see if the sensor is freely moving,hope this helps
Jul 07, 2009 | Canon Laserbase MF6530 All-In-One Printer
Paper jam in printer
Check the path path by pulling out the cartidge/ drum unit, the tray(s), and check the fuser(hot, turn off the printer and let it cool!) in the rear of the printer there is an access door(green/ blue tabs show where to open and look:).   If your still showing jams sometimes a sensor (small black arm) is dirty (blow with compressed air), out of place, snagged, or faulty.
 Blow compressed air around the arms and look at the sensor arms. They should be able to move freely. (paper can get torn and wrapped around the sensor arm causing a fault: tweezers and patience)
Turn on the printer and see if that works for ya.
The only other jams come from the feed tires not being able to pick up the paper or the resist pad/roller being worn out and letting two sheets or more in at once (but this doesnt sound like your problem).
Much luck
Mar 19, 2009 | Dell Office Equipment & Supplies
HP Printer 4280
i pulled jamed paper out of my hp81oc from front. now it want pull papet through? can it be fixed?
Jul 28, 2008 | Office Equipment & Supplies
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
23 people viewed this question
Seeker5211
Seeker5211
