Question about Pioneer DVR-520H DVD Recorder
Random power failure
Unit will work for weeks and then lose power. To resolve this, you have to disconnect it from power supply for about 8 hours and then reconnect. Anything less is not long enough for it to discharge whatever build up is causing the failure.
Completely disconnect the power cord 15 mn and then reconnects, It's a power problem i think that is the condensators which are out of service
Posted on Nov 21, 2009
Why does my JVC KD-DB95BT car stereo lose power?
Power lost on two units in one car is a little unique. Does it lose power in the middle of a trip or when you first get into car? I would recommend bench testing to direct 12v unit to see if car is causing voltage loss.
Jul 25, 2014 | JVC Car Audio & Video
No power on light
That's interesting.. After researching that model I can tell you that it has an intergrated internal power supply(transformer) which does contain a fuse. It is located where your power cord plugs into, inside the unit, start with that. Was it plugged into a surge protector? When you had the power failure the second time was there a fluctuation of power, ie your lights in your house flickering on or off or increasing, decreasing in brightness? This will help me determine if it's something else. Also be sure to check your power cord, look for any kinks, breaks, chips in insulation. Anyway Good Luck
Sep 29, 2007 | Sony VPL CS4 Multimedia Projector
Sharp Carousel II (R-9H83) loses clock, digital display dims
I think there are some electrolytic capacitors in the power supply to be replaced.Because there are relatively few, it would be good to change them all for more safety
Jun 02, 2014 | Microwave Ovens
Ford focus random power loss
Did you ever fix the problem I have a 2005 focus and its doing the same thing
Feb 01, 2013 | 2005 Ford Focus
Vizio hdtv went POP then black while watching a program. Reset did not help.
sounds like a power supply failure open the unit and inspect the power supply for any damage type bad capacitor into google and look for any bad caps on ur power supply
replace them
if all else fails replace the power supply
please make sure to disconnect your tv from the mains and wait at least half an hour before doing any kind of work to it as it may still hold a charge that could harm you
May 15, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
Hi My Fisher & Paykel Model: E522B starts beeping for no reason at random times. When I press the cooler/warmer settings it stops but will start beeping again randomly at a later time. Please...
Hi - I believe the problem is the power module located on the rear of the machine. I have not done work on F&Paykels for a long time.
Whats happenning is the controls is picking up an error with the input power supply, the modules perhaps got an intyermittent issue.
Try this turn your fridge off & back on again - the E522B will start to beep indicating the lose of power which is exactly whats happening to the unit at the moment, to eliminate the beeps you reset with the temp button on the inside.
Jun 14, 2011 | Fisher and Paykel Active Smart E522B...
8 year old Air conditioner only used in the last 3 years more than a week or two a year. capacitor changed last year Unit was working a week ago now fan is not turning, Connector clicks when turn on...
Outdoor units require there own power supply, check the breaker panel and the fuses in the disconnect switch box next to the unit if there are fused, If the capacitor that was changed last year was not the right rating or configuration it may need to be corrected. One of the most common mistakes is to find a dual run capacitor with on side not functioning and jump in a capacitor for the non functioning side, if this was done it needs to be corrected with the proper capacitor or capacitors.
May 24, 2011 | Carrier 38CKC036 Air Conditioner
Yamaha RV-V2200 without power loses settings under 24 hours
It could be a battery, a bit like the type you get in watches. But I reckon it's a memory retention capacitor that has failed. These are small looking things that look like electrolytic capacitors that have been squashed from above. They appear to have a working voltage of around 5.5 volts too. I am enclosing a picture of one, though it could vary in style. You might find it near the main display of the unit.
Apr 30, 2017 | Yamaha RX-V2200 Receiver
I have a Panasonic KX-TH112. It showed an error and I disconnected it for a while. Now it will not charge at least it does nothing.
Exchange the power supply from one of the satellite handset recharge units. The power supplies are same model number. In my case the base unit would not show any power. When I exchanged it with the satellite power supply, the base worked properly and the old base power supply would actually work fine with the satellite charger. . . probably because the satellite charger has less power requirement. Also, my system had some noise in the line prior to the failure -- for about 2 weeks. This solved the noise problem as well.
Sep 23, 2008 | Lands Phones
LG 42LC2DR
The SATA (data) cable on the HDD could have an intermitantly fault.Also check that you unit has the current software version.
Change the SATA cable or contact your local service center.
Dec 11, 2007 | LG 42LC2D 42 in. LCD HDTV
Pioneer DVR-520H DVD Recorder Logo
567 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
