Question about Avanti Hot and Cold Water Cooler
Water won't come out of the cold water dispenser.
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
SOURCE: Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Posted on Nov 15, 2008
  • 400 Answers
SOURCE: hamilton beach tabletop water dispenser for hot
The water selector valve is fautly and needs to either be stripped and cleaned or replaced.
Posted on Mar 09, 2009
SOURCE: sunbeam cold and hot water dispenser
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
eventwholesa
SOURCE: avanti water cooler
Water Despencer Avanti wd29ec, the blue water release valve is leaking. It has a constant drip that overflows the water catcher on the 5 gallon water dispenser. what should i do
Posted on Feb 24, 2014
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Replaced water filter and still won't produce water
If the ice maker works and the dispenser does not the most likely cause will be the=> WR57X10032 Dual Water Control Valve
In rare cases the water will freeze in your water tank or iside of the freezer door but if this has not happened before and you are seeing no extreem cold temps in lower half of refrigerator section where the water tank or coil of water line that cools the water before it reaches dispenser you will possibly resolve this problem by replacing the dual water control valve. Let me know should you have questions, Thanks Sea Breeze
Feb 27, 2013 | GE GSH25JFR Side by Side Refrigerator
Water won't stop coming out from the cold water dispenser
The cold water dispensing valve can be stuck or defective. Sometimes jiggling the valve can make it stop running
Sep 30, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water is not cold
NO SOLUTION, THERE'S JUST NO EXTRA TUBING. Domestic refers with water dispensing feature will have a coil of plastic water tubing tucked away in the refer behind a drawer or at the bottom; it hold s cedent amount of cold water when you dispense it. However, You won't find this additional tubing in a Samsung refer. This fridge is made 'abroad' by folks don't have the same standards as the U.S. The icemaker, for instance, is found to be accepatable by their standards when it makes 72 cubes per day; HAH! We use more than that for dinner. We buy bagged ice and use a Brita pitcher. I will switch back to Whirlpool or Maytag when this thing craps out.
Aug 07, 2012 | Samsung RF265AA Bottom Freezer French Door...
Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Nov 03, 2009 | Kitchen Appliances - Others
Water temperature from the water dispenser of our new refrigerator is equal to the environment temp.it is not cold at all.is it normal?the dispenser produces ice cubes but not cold water
You may not have filled the water reservoir when you hooked up the fridge. Run about 2 gallons of water through the dispenser. Then wait about 12 hours before you draw more water. This way the dispenser will fill and have time to cool down. It should stay cold after this.
Aug 29, 2009 | Samsung Refrigerators
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
Avanti Hot and Cold Water Cooler Logo
254 people viewed this question
Top Avanti Water Filters & Coolers Experts
John Tripp
John Tripp
john h
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
