Question about Teac PD-D2610 5-Disc CD Changer / Player
When it looks for the TOC reading it will not
TEAC PD-D2610 CD Player: when it looks for the TOC reading it will not recognise any disc
localwonder
  • 6784 Answers
SOURCE: Teac PD-1200 Compact Multi Disc Player
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly.
Posted on May 29, 2009
  • 86 Answers
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Posted on Oct 09, 2009
SOURCE: After 16 months our PD-D2610 CD changer has
I read enough comments from unhappy TEAC owners with similar problems to learn that the drive motor is to blame and that repair sounds like sending good money after bad. I'm going to buy a Sony changer.
Posted on Nov 19, 2009
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
taran_2005
  • 10515 Answers
SOURCE: I turned on my TEAC
Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminum cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should then be OK. If it has been forced, the aluminum cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
H300 mk 111 hi-fi system. Why is the remote sensor on cd player (PD-H300 mk 111) not recognised by the remote control unit (RC-1091)?
You have this backwards. The remote control sends signals to the sensor on the CD player. It is possible that the remote batteries need replacement or that the remote has a malfunction.
Jul 24, 2015 | Teac PD-H300 CD Player
My teac 5 cd player wont play any cd's there has been suggestion that the laser reader is not working so how do I fix this?
It is a job for a Technician and there are no user serviceable parts inside a unit like this- people usually wreck the units as they are delicate.
The Laser pickup does not often times go bad that easily and that is just a persons way of sounding like they know what they are talking about but without substantial proof I do not just take that as fact. Many many other things can cause a malfunction other than the laser- it can be a nad spindle motor, platter distance can be wrong and can even be dust on he lense. I have working Sony decks here from 1987- these are the original pickups- same kind you have I bet.
Dec 19, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
Display Panel
The problem is not with the display panel, it is with the changer mechanism. It may cycle through all five disc positions without playing a single one
Dec 03, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
After 16 months our PD-D2610 CD changer has started misbehaving. Some of the 5 positions work fine but positions 1 & 4 almost never work.
Nov 18, 2009 | Teac PD-D2610 5-Disc CD Changer / Player
Cd disk player won't spin cd
HI, this is a basic spin motor fault. This unit will require service at this point. The actual affected motor is buried within the optical assembly, and will require a set of precision tools to disassemble correctly and safely.
Replacing this damaged spin motor will correct this issue.
Sep 10, 2009 | Teac PD-D2610 5-Disc CD Changer / Player
I mistakenly cleaned the with a cleaning solution a few years ago, since then the Teac PD-H500 has trouble recognising any CD, hence will not play the CD; instead all I hear is a clicking noise. over the...
If I were you I would get hold of good magnifying glass or one that jewelers use and look into the lens of the device (power off of course). If you can see a scratch or smudge or damage then that's the reason the CD wont read.
Sorry if it is then it's likely you will need a new one and they are expensive.
Jun 16, 2009 | Teac PD-H500 CD Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Jul 04, 2008 | Teac CD-P1120 CD Player
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
Teac PD-D2610 5-Disc CD Changer / Player Logo
77 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
