Question about Praktica DCZ5.0 Digital Camera
My lens nt comming out n no display on lcd.. - Praktica DCZ5.0 Digital Camera
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
What is it features ?
MPN Capture 1300 Key Features Resolution 1.3 Megapixel LCD Screen Size 1.5 in. Digital Zoom 2x Lens Interchangeable Lens Not Interchangeable Lenses Focus Type Fixed Focus Image Quality Image Sensor Type CMOS Camera Resolution 1.3 Megapixel Image Resolutions 640 x 480 • 320 x 240 • 176 x 144 Exposure Control Aperture Range f3 (w) Storage Memory Type CompactFlash Card Type I Built-in Memory Size 8 MB Compression Modes Fine • SuperFine • Normal Compression Type JPEG Flash Flash Type Built-In Flash Functions Flash Off • Auto Flash • Fill-in Flash Viewfinder / Display Viewfinder Optical LCD Screen With LCD Screen LCD Protected Position Without LCD Protected Position Interfaces Interface Type USB Power Supply Battery Type 4 x AA Batteries Included Features Built-in MP3 Player Unknown Built-in Microphone Without Built-in Microphone Built-in Speaker Without Built-in Speaker Tripod Mount With Tripod Mount System Requirements Operating System Microsoft Windows 2000 • Microsoft Windows 98 • Microsoft Windows ME • Microsoft Windows NT • Microsoft Windows XP Warranty Warranty 1 Year Miscellaneous Included Accessories 4 x AA Batteries • Software • USB Cable • Hand Strap UPC 647499779101
Mar 22, 2011 | Veo Capture 1300 Digital Camera
The Remote Control dos^nt works
Since any remote system uses two ends, a transmitter and the receiver inside the set itself, the failure could be in either part. If you have a digital camera or camcorder, turn it on so you can watch the LCD display and aim your remote at the lens of it and press and hold a button that should be working. The infrared can be seen as visible light on the display since the camera's element can 'see' the IR.
If no button causes the remote to send code, then the remote is bad and will need replacement.
A good source (not cheap) is:
Remotes.com
Even if costly, it will be less than replacing the internal receiver in your set.
Dec 30, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Have a Memorex MVD2050-BLK. Insert disk then displays loading then "no disk. Would like to clean using a cleaning disk but it won't load. What gives?
sure because a cleaning disk doesnt clean the laser lens at all;you will have to clean by your self using a qtips and wood alcool ;and wipe the lens gently and dot not apply to much pressure on lens while you wipe it.
if it does nt works after that you may have to replace the lens assembly or buy a new one.
hope that will help you
regards A.S
May 13, 2010 | Memorex MVD2050-BLK DVD Player
Text is not normally displayed on lcd
Are you saying the aperture numbers are not being displayed on the camera LCD or view finder? If so it depends lens and camera. Some cameras and lens connect, but do not an electrical connection. Some of the newer Nikon cameras are not designed to work with some lens. Now, if that lens works on another camera of the same type then the camera needs repair. Sometimes cleaning the contact at the opening of the lens mount does the trick.
Apr 30, 2010 | Tamron Photography
Problem with my Nikon Coolpix 5700.
Hi there, its a problem of the lens sensor, So i suggest you please contact with you service center. Thanks.
Feb 19, 2010 | Nikon Coolpix 5700 Digital Camera
Fuji FinePix A345 Lens cover does not open and Zoom error displayed on LCD
Lens cover does not open and Zoom error displayed on LCD.
Aug 25, 2008 | Cameras
Camera ex-p600
That is a lens error code. It needs servicing or replacement. I repair these all the time. and know that this is common with most digital cameras.
Mar 02, 2008 | Casio Exilim EX-S600 Digital Camera
Kodak easyshare v530
Kodak easyshare V530 camera turns on then straight back off again bought a new battery but still does the same. Lens goes out a bit but then straight back again.
Feb 20, 2008 | Kodak EasyShare V530 Digital Camera
"00" Apparture
If an aperture of "00" is displayed on the camera's LCD panel, perform the following steps in order. Check after each step to see if the problem remains, and proceed to the next step if it does. (In some cases, you may see "Err 01" displayed on the LCD panel.) 1. Check if the lens is correctly mounted on the camera. If no lens is attached to the camera, "00" will be displayed for the aperture value. 2. Clean the lens contacts. Turn the camera's power switch to OFF, and then detach the lens from the camera to clean the contacts. Use a blower to blow away dust on the lens. Do not touch both the camera's or lens' electrical contacts with your fingers while cleaning the lens. Turn the power switch to ON again and check the aperture value displayed on the LCD panel. Refer to the Instruction Manual provided with your camera for instructions for detaching or mounting the lens. Also, prevent any foreign materials or dust from getting into the camera through the lens mount, and be sure not to damage the contacts. 3. Remove the battery pack. Turn the camera's power switch to OFF and remove the battery pack. Then reinsert the battery pack, and then turn the power switch to ON again.
Aug 29, 2005 | Canon EOS-1D Mark II Digital Camera
Cameras Logo
37 people viewed this question
Top Praktica Cameras Experts
Jose Ma DM.
Jose Ma DM.
Are you a Praktica Camera Expert? Answer questions, earn points and help others
