Will start of by printing 2 pictures then will only print half a picture using xp home and 2d design
IB4G2008
  • 3587 Answers
SOURCE: Kodak EasyShare Printer dock prints bottom half of picture
does this happen with the test page, too?
Posted on Feb 27, 2008
  • 36 Answers
SOURCE: Only half of picture is printing
Kodak sent me an email that said I need to reflash the firmware
I will post if that helps
MM64
Posted on Apr 02, 2008
  • 31 Answers
SOURCE: Printing only 2/3rds of the picture lengthwise
The problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
  • 526 Answers
SOURCE: every 5 lines it only prints half of the nexct line. Put picture print just fine
like some of the other printers, it could br 1 of 2 things,
first try a cleaning. it could be the nozzles that handle the 5th line are partially clogged.
if cleaning does not work, it seems like the printhead will need to be replaced. It might have to be serviced by a canon service center if the printhead is not user replaceable.
thanks
Posted on Apr 15, 2009
SOURCE: Printing only bottom half of picture.
I had the exact same issue with mine! I didn't manage to fix it, but I know exactly what the issue is. If you open the printer, you'll find a black rectangular box above where the film fits inside the printer. This black box is connected to the board above it, and is supposed to press down against the film, and then against the paper for it to print properly. There is a little bar above the rectangular box, and there should be two plastic pieces on both ends of this bar. The bar is also connected to the gears, and when the gears move the bar, the two plastic pieces coming off of the bar push the black box down. When I looked at mine, only one of the plastic pieces was doing its job; the other one was broken, and was sliding on the bar. Tried some super glue, wouldn't work. I suggest tossing it out like I did, unless it's still under warranty or you want to try fixing the plastic piece so the printer head gets pressed down all the way.
Posted on Jun 22, 2009
Cannot see exported images in 3d view .
you might have lower video card specs, or the version is not compatible with os
Jul 05, 2012 | 3M Chief Architect Home Designer Suite 8.0...
The printer repeatedly prints half a picture then turns offline. now it's completely offline.
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Oct 15, 2010 | HP Photosmart 8050 InkJet Printer
Prints half the picture
Most of these issues are caused by drivers in the computer that are not agreeing with the pritner.
I would doubt its something hardware as its prting half.
it also could be a setting.
let me know
Thanks please do leave ratings and feedback
May 08, 2010 | Kodak EASYSHARE Plus Series 3 Thermal...
Microsoft photo & Print studio 2002 will not print cards
This software is no longer supported by Microsoft. It doesn't work with Vista and It won't work with Windows XP once the service packs are installed. The product was discontinued in 2004. You can see for yourself by going to Microsoft.com and select Picture It for details.
Feb 20, 2009 | Microsoft Picture It! Publishing Platinum...
Black ink is faded or doesn't print at all
Once installed, Kodak All-in-One printer Home Center software allows you to print, copy, scan, and configure your All-in-One printer from your Windows XP or Vista computer.
To open the Home Center software window on your computer, use the Home Center icon on the Desktop or in the Start Menu
From the All-in-One printer Home Center main menu, selecting one of the six menu items enables you to:
  • Scan pictures and documents
  • Enhance and copy pictures
  • Enhance and print images
  • Configure settings for printing, copying, and scanning from the control panel
  • Access the Kodak Tips and Projects Center Web site.
  • Order supplies from the Kodak Web site.
Dec 17, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
How to print picture using 10x15cm photo paper? usually the pictures printed only half
Hi
1) when you begin to print have you set the paper size to the size you require ?
2) If not when you press print a grey box appears to comfirm printing yes!
3) press properties top right of page
4) open tab basic
5) Alter paper size to correct size
6) Also check your paper setting on the programme you are using to print from,
7) Also that the orientation is correct "portrate or landscape"
grandpaben
Nov 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
I have the same problem where only the bottom half of my photo prints. It worked fine for a long time. I even tried flashing the printer up to the 2.11 firmware version from 1.90 - still nothing. Changed paper and cartridge. NOTHING. Tried attaching it to both my PC & MAC and even print stand alone picture from camera and a SD memory card on the side. NOTHING.
I think the problem is with Kodak... My trouble started when I decided to move my Dock Printer from PC over to MAC. The new drivers have you flash the Firmware. To do this, you first must hold down the Print and Red EYe Button (The button directly to the right of the big print button) with the power cord unplugged and then plug it in holding the buttons in for 2 seconds afterward.
This put the printer into Edit mode and allows the firmware to upgrade the printer. Once I did that, THAT'S when my problem started. I think these crappy printers can NOT self calibrate and they must be factory set. Most likely, they need to do it at the factory themselves and are all to happy to charge you to ship it off and do it for you.
THANKS KODAK!
What a POS.
Mar 20, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
32 people viewed this question
jasbo
jasbo
