Question about Syntax SVX400 (SYSVX400) Motherboard
Hello, I don' know where to put the HDD led cable, and all the small wires from the start button and the front USB ports. Can you help me ?
Try:
2-4 MSG LED
6-8 PWR BTN
1-3 HDD LED
5-7 RST
Hope this helps..
Posted on Jun 14, 2010
  • 104 Answers
It should be in the motherboard maual. if u dont have one try download one online
Posted on Sep 28, 2009
Motherboard wiring for t6532
eMachines T6532 uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
Scroll down a little, hover your mouse cursor on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Scroll down a little. Under the Download subheading, click on the blue - E7207v2.0.zip
[Version 2.0 / English / 7.1MB / 2006 - 05 - 24 ]
Click on the country name nearest yours.
A small window will come up -
Opening E7202v2.0.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
If Not; left-click in the small empty circle to the left of Save File.
Go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name.
In the next small window go to the far left, click on -
Extract all files.
At the bottom of the next 3 small windows, JUST click on Next, Next, and Finish.
In the last small window DOUBLE-click on the file name - 7207v2.0(G52-M7207X5)
There is the motherboard manual
Example A;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
(Power On switch, Power On LED light, HarDDrive activity LED light, and Reset switch IF used)
The Front Panel header is JFP1, in the bottom/right corner of the motherboard.
Two rows of contact pins.
4 on the Top row.
5 on the Bottom row.
Pins across the Top row are numbered EVEN.
Pins across the Bottom row are numbered ODD.
Starting from the Left side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting from the Left side going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected
It is reserved for the factory to use.
(Believe 5 Volt test point)
D) Pins 2 and 4 are used for a Power On LED, that has two wires.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
JFP2, or also known as Junction Front Panel 2; is above JFP1, and is situated Vertically, instead of Horizontally like JFP1.
(Below purple SATA data cable connector/ Right; and to the immediate right of the CMOS battery))
4 pins on the Left side, 3 pins on the Right side.
Pins on Left side are numbered EVEN.
Pins on Right side are numbered ODD.
Starting at Top of Left side coming down;
Pins 8, 6, 4, and 2.
Starting at the Top of the Right side coming down;
NO Pin 7, pin 5, pin 3, and pin 1.
Pins 2 , 4, 6, and 8 are for an internal speaker. Used to hear BIOS Beep Codes.
Pins 1, 3, and 5 are for a Power On LED light, that has 3 wires.
Used for a dual color Power On LED light.
For example Turbo Mode is Green, and Normal Mode is Yellow.
(Which was cr@p.
Turbo mode was actually normal, while normal was slower)
Example B)
Front panel USB ports. (Connectors)
JUSB1 and JUSB2.
EACH USB header supports TWO USB ports.
Look at the pinout on Page 40.
VCC, USB4-, USB4+, and Ground; is one USB connector. (port)
VCC, USB5-, USB5+, and Ground; is a second USB connector. (port)
Note the USB4-, and USB4+; and the USB5-, and USB5+
Now look at a USB pinout. Male and Female,
http://en.wikipedia.org/wiki/Pinout#USB_pinout
VCC = +5 Volt
USB4- and USB5- = -Data
USB4+ and USB5+ = +Data
GND is Ground.
You can have 4 USB ports in the Front Panel, or add extra ones to the rear panel. (I/O area)
ONE of those USB headers; JUSB1 or JUSB2; can be used for a Card Reader.
A Card Reader has Two USB cables, and uses One USB header on the motherboard.
Which one? Junction USB1, or Junction USB2?
Pick one.
Doesn't matter.
BIOS will set an IRQ for it.
(Interrupt ReQuest)
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 02, 2013 | eMachines Computers & Internet
Need circuit diagram for HP m8100 GC673AA
HP Support > Pavilion Media Center M8100n Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3440614&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Motherboard Specifications, MCP61PM-HM (Nettle2 {HP name} ),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077676&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3440614
The area of contact pins on the motherboard, that the Main wires connect to, is the Front Panel header.
(Power On switch, Power On LED, HarDDrive activity LED, etc)
The Front Panel header is Black, rectangular in shape, and is situated in a vertical position; located in the Bottom Right corner of the motherboard. (Next to the mounting hole)
It is a standard 9-pin HP Front Panel header,
http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the 9-pin Front Panel header photo, and pinout.
The 4-pin side is the EVEN side. Pins 2, 4, 6, and 8. There is NO Pin 10.
The 5-pin side is the ODD side. Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode, so it is redundant to call it a light)
IF the HDD LED is dim when the harddrive is active, (IN use), switch the wires around.
C) Pin 9 is N/C. Not Connected. Reserved for factory use, and it is +5 Volts.
D) Pins 2 and 4 are for the Power On LED.
Scroll the HP Support Motherboard Specification page down. Click on the + sign next to Motherboard Layout.
Left to Right on bottom edge of motherboard, Internal Connectors;
AUDIO_1 is for the audio ports on the Front Panel.
ATX_IN is where the small audio cable from the optical drive plugs in.
(CD/DVD drive)
IF TWO optical drives are used; the Main, or Primary optical drive, is connected with the small audio cable. NOT the secondary optical drive.
HD_AUDIO also connects to audio ports in the Front Panel.
May be mistaken, but don't believe SPDIF_OUT header is used.
1394A1 header is for the Firewire ports in the Front Panel (1394a)
USB 2 and USB 4 headers are for the Front Panel USB ports.
USB 1 and USB 3 should be for a Card Reader.
Need where the power cables go, and what they look like? Just post back in a Comment.
(Be SURE to FOLLOW Anti-Static Precautions)
Regards,
joecoolvette
[ Didn't think you actually wanted an actual circuit diagram. That is copyrighted by HP, and Elitegroup Computer Systems. (ECS)
Dec 03, 2012 | Computers & Internet
Motherboard diagram Acer eMachine MB DA061/078L
Hello? Tap, tap on the monitor. What are you reading from?
http://www.ebay.com/itm/Acer-MB-NB107-001-DA061-078L-Motherboard-eMachines-08120-2-780G-AM2-Desktop-/280919767281?pt=Motherboards&hash=item41681f78f1
The area of contact pins on the motherboard, that the main wires go to from the Front panel, is the Front panel header.
Motherboard installed in computer, the Front panel header is at the Bottom/Right.
Two rows of 7 pins in a small black rectangular plastic block.
http://www.ebay.com/itm/Acer-DA061-078L-Motherboard-eMachines-EL1200-X1200-AMD-780G-Socket-AM2-DDR2-/140825131784?pt=Motherboards&hash=item20c9d4fb08
TOP row of pins is numbered EVEN.
BOTTOM row of pins is numbered ODD.
Starting on the LEFT side going towards the Right, TOP row:
Pins 2, 4, 6, 8, (NO 10), 12, and 14. Again, there is NO Pin 10.
Starting on the LEFT side going towards the Right, BOTTOM row;
Pins 1, 3, 5, 7, 9, 11, and 13.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
If the HDD LED is dim when the harddrive is active, switch the wires around.
2) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
3) Pins 2 and 4 are for the Power On LED (Light)
4) Pins 6 and 8 are for the Power On switch.
5) The rest of the pins are N/C. Not Connected.
Don't forget to plug the 4-pin ATX +12 Volt power cable in,
(Top left corner),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Regards,
joecoolvette
Sep 06, 2012 | Computers & Internet
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
I dont no to connect the front wires in mother board
The front wires are usually for power, hdd led. power button and reset button and sometimes extra usb ports and audio ports. All motherboards have a small section that has 8 to 10 grouped pins protruding that you can attach these wires to. The motherboard will diagrahm where the pins hsould go. For example the light for the hard drive wires are probably labeled "HDDLED" and there is two of them. One positive charge and and ground. On the motherboard, in the grouped pins there is a small label that goes:
''___'
'_____'
HDDLED
PWLED
It may look like this but in a different arrangement. What does this mean? Connect HDDLED to the top two pins. Doesn't matter which way the positive and ground go. And connect the power led PWLED to the bottom pins. Follow this for all the other labels.
Hope this helped.
Jul 05, 2011 | Computers & Internet
Idnt knw hw to cnnct power switch , hdd led ,speaker , reset.led+ , led- . pls help me by sorting out my problem.by full description . and photos of connecting cables.
''___'
'_____'
HDDLED
PWLED
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
I have a PLE01 mother board and i need to plug in the hdd,ldd and ect plugs and i don't know how they go as i do not have the manual and cannot read the small print can u help
Today's motherboard are easy to setup because mostly are now color coded like those connection ports.All you have to do is place the cables according to their color coded ports. Connectors are easy to identified because they are also labeled with name. Like the picture below.
Connections ports on the motherboard are also labeled similar to the connector cables above or have a similar abbreviated names like PSW for Power SW.
I hope this could help you..
Please don't forget to rate. Thanks..
Mar 24, 2010 | Intel Motherboard
Wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
Syntax SVX400 (SYSVX400) Motherboard Logo
142 people viewed this question
Top Syntax Computers & Internet Experts
Steven Burn
Steven Burn
John Anderson
John Anderson
T-Comtech Repairs
T-Comtech Repairs
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
