Question about Microsoft Office Standard for PC
Log.files i thought i could unstall the freeze. so i went to unstall and now it does not move when i click on the control it just stays there. can you just install it back on i will let it stay on
  • 48 Answers
Could you Pl write your problem in detail
Posted on Jan 01, 2008
Remove error106
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
or
NTFS Partition
1. Click the Start button, point to Settings, click Control Panel, and then double-click Services.
2. Select the Event Log service and click Start up. Change the Start up Type to Disabled, and then click OK. If you are unable to log on to the computer but can access the registry remotely, you can change the Start up value in the following registry key to 0x4:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog
3. Restart Windows.
NOTE: When the system starts up, several services may fail; a message informing the user to use Event Viewer to review errors may appear.
4. Rename or move the corrupt *.evt file from the following location:
%SystemRoot%\System32\Config
5. In Control Panel Services tool, re-enable the Event Log service by setting it back to the default of Automatic start up, or change the registry Start up value back to 0x2.
FAT partition (Alternative method)
1. Boot to a MS-DOS prompt using a DOS bootable disk.
2. Rename or move the corrupt *.evt file from the following location:
3. Remove the disk and restart Windows.
When Windows is restarted, the Event Log file will be recreated.
hope this helps
Jul 03, 2012 | Computers & Internet
Unstall veritas update manger
Simply use windows default Add or Remove tool.Start > control panel > Add or Remove programs > select required Program > click uninstall... . After un-installation use system cleaner to remove remaining corrupt registry files and unwanted files related to this software, because it freezes the systems. I would recommend Reginout for this purpose.
Apr 15, 2012 | Computers & Internet
Can't sign in
check your user id and password. Check for capital letters. Check also your internet connection. If your account is compromised, go on with the long procedure. click forget password and answer some question.
May 17, 2010 | Yahoo Messenger
Not working my pasword
First try to see that your password is correct or not. Log into mail.yahoo.com and if you are able to login website. Then try terminating yahoo from task manager ( do ctrl+alt+del to open task manager). Go to processes tab on task manager and search for YahooMessenger.exe, right click and click on end process. Start yahoo messenger again and try logging in again.
If this doesnt work, you can try uninstalling and installing the yahoo again. But after unstallation make sure to remove all the remain of files related to yahoo. Hope this solves the problem, it did for me.
May 17, 2010 | Yahoo Mail
Hitachi SimpleDrive 320GB: Error moving file: Access denied!
The problem may be that your Security settings for the drive are not configured to give you Full Control.
In Explorer, right-click on the Hitachi drive and choose Properties.
Go to the Security tab.
Find the User you are trying to use and click on it.
Under Permissions, click Edit and enable Full Control for that user.
That should give you the ability to do what you need to.
If Windows won't allow you to change the setting, it's because you don't have Administrator priviledges. In that case, log out and log back in as an Administrator and go back and make the changes.
Nov 04, 2009 | Computers & Internet
Icons freezing after computer starts up
I think your account might be corrupt, and should probably be deleted. I would highly recommend backing up your data to an external hard drive or create a temporary folder on your C drive, then create a new user account through the control panel. Once this is done, log off of the current account, login to the new account. Locate the icon titled My Computer. Right-click the icon and choose Properties. Look for the tab titled Advanced- click it. Midway down under User Profiles there should be a button titled Settings- click it. IN the list that populates with the user accounts (profiles) stored on your machine, highlight the account that you were just previously logged into (the original account that you were experiencing problems with). Once the old account name is selected, choose the button titled delete. Now, you can restart and log back in. This should put you back at a ready state. It will also resolve your problem if spyware was to blame for your inital problems. Let me know.
Mar 26, 2009 | E-Machines eMachines Desktop PC
Unable to remove programme
Try to unstall using the add/remove program.
Here's the step
1. Click start
2. Click control panel
3. Click add/remove program
4. Choose the program you want to remove then click remove.
Hope that will solve your problem
Thanks
Dec 01, 2008 | Philips J44414
My RCA Lyra RD1072A just doesnt play songs
it freezes at the start menu just saying RCA and others times it plays a song and freezes when i turn the volume up or down can someone anyone help me please...thanx
May 16, 2007 | RCA Lyra RD1072 MP3 Player
Microsoft Office Standard for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
