Question about Dell Dimension 4600 PC Desktop
I want to connect a Tv on my dell 4600 using the s video
  • 403 Answers
You need to have a card installed on you computer that is for watching TV, or Satellite. TV card. You can get them pretty cheap now, better prices on e-bay. Need to know what kind of expansion slot you have as this is important when buy the card. Go to this link to download a manual on your desk top. There are two selections so just pick which one you have.
http://support.dell.com/support/edocs/systems/dim4600/en/series_en.htm
Let me know if this helps you and if I can help you with anything else.
JimmyC
Posted on Sep 28, 2009
  • 344 Answers
Providing you are talking about pushing video from your computer to the TV, i can help...You need to adjust the video out settings via the control pannel.....now if your are trying to watch the tv using your laptop you need a tv tuner card or compatable hardware
Posted on Sep 27, 2009
  • 438 Answers
Use tv tuner card!!!!!
I get an error message of signal not compatible on my Sharp Aquas TV when connecting my Dell 4600 to the TV
Are you tying to connect a DVI input or a VGA input (DVI is usually a white cable, VGA is usually blue).
Sep 13, 2013 | Dell Dimension 4600 PC Desktop
My pc wont recognise my tv as a second monitor - conected with VGA cable
the video card you used have a capability for dual monitor..so 1st thing that you need to do is to make sure that the computer recognized the 2nd monitor and activate dual monitor capability on the nvidia panel..after that on your tv select the proper source(like VGA, HDMI1 etc.) on which you'll be able to see the the video from the computer to your TV..
Jan 31, 2012 | Dell Computers & Internet
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
Extended Desktop on Dell Dimensions 4600
yes your right..leave it set to AUTO BUT ONLY USE THE ATI CHIP SET VIDEO CARDS.
Dell Dimension 4600 We saw great image quality from the 17-inch E171FP analog LCD monitor that accompanied our review system. Text looked sharp and evenly focused at all sizes, while colors appeared lifelike, with evenly saturated tones in our photo test screen, in a DVD movie, and during a session of Return to Castle Wolfenstein. As part of a new case design for Dell's midrange Dimension line, the 4600 has eight USB 2.0 ports, more than on most value (and some power) systems: six on the back and two up front. An audio port for connecting headphones sits next to the front USB ports.
The compact 4600 does not have the tool-less accessibility of its predecessor, the Dimension 4500, although opening the case is easy: Just depress a thick L-shaped lever and lift off the side panel. You'll need a screwdriver to add a PCI card or a hard drive; unlike the 4500 series, which secured expansion cards and drives with innovative quick-release mechanisms, the 4600 series uses screws. Our test configuration had only one available drive bay (a vertically mounted internal bay), and it's a struggle to use it. You must remove four screws (two on the bottom of the case and two inside) and take out the bay holding the existing hard drive along with the empty bay that's crammed up against the front of the case. The two open PCI slots are reasonably easy to access, but to reach the two open memory sockets, you must push aside a snarl of data and power cables.
The Dimension 4600 we tested came with a 2.8-GHz Pentium 4 processor and 512MB of DDR400 memory. It earned a PC WorldBench 4 score of 122, about average for similarly configured systems. The ATI Radeon 9000 Pro graphics card is not a top-of-the-line board, but it yielded solid frame rates in our gaming tests. And it's perfectly fine for playing games at moderate resolution, especially considering that the bundled LCD monitor won't display anything higher than 1280-by-1024 resolution. It has a combination DVI/analog-out port (you use an adapter to hook up an analog monitor), plus S-Video-out and composite-out ports to output video to a TV.
Please leave comment and feeb back.
Thanks
Feb 24, 2010 | Dell Dimension 4600 PC Desktop
Wireless connection with Dell 4600
they sell USB wireless adapters, that should do nicely.
Don't forget to rank the advice!
http://www.aa1consulting.com
Jul 27, 2009 | Dell Dimension 4600 PC Desktop
I want to put 4 monitors on my dell 4600
You need a video card capable of supporting four monitors. This is usually done with an SLI setup where the motherboard supports multiple video cards and each card supports two monitors instead of four, but the 4600 does not support SLI. Check out this link for a list of cards and methods that will work.
Apr 20, 2009 | Dell Dimension 4600 PC Desktop
Connecting dell dimension 4600 to home theater.
If you have either an Optical audio out connection or a pair of rca connectors you should be able to do this
Jul 10, 2008 | Dell Dimension 4600 PC Desktop
Computer to tv
you'll need a video card that has an S-Video out port and a TV that has S-Video in. Generally, adapters and converters don't work well.
Once connected with an S-Video cable, you should be good to go.
Jun 27, 2008 | Dell Dimension 4600 PC Desktop
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
330 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
