Question about Metz mecablitz 45 CL-4 TTL Flash
Ttl dedicated flash gun operating instructions
How do I get set up with this equipment?
    Champion:
    Scholar:
  • 216 Answers
What equipment are you talking about?
Please give as much as possible.
Alexander
atdlee@netzero.com
Posted on Dec 19, 2007
Could the Sakar Dedicated Ittl Flash work For Nikon D60
Probable will not work on the Nikon's hot shoe because the contacts on the Sakar flash gun won't match the contacts on the Nikon's hot shoe.
You can use the Sakar flash gun as a slave flash by connecting a optical flash trigger to the Sakar flash gun and use the Nikon's flash to trigger the Sakar slave flash.
Feb 27, 2013 | Sakar Dedicated Ittl Flash For Nikon D60...
ARE THE INSTRUCTIONS FOR THE MENTIONED FLASH GUN AVAILABLE
Yes.
http://www.metz.de/en/service-support/instruction-manuals/photo-electronics/mecablitz.html
May 20, 2011 | Metz 44 AF-4 for Canon TTL Flash
Why does my sb-800 doesn't show the meter and ft. and doesn't have a guide GN menu?
Since SB-800 is a dedicated TTL flash, it doesn't need you to manually set the values. The flash can communicate with the Nikon cameras automatically in TTL mode.
Sep 22, 2010 | Nikon Speedlight SB-800 TTL Flash
Use of the mecablitz 60ct-4
Go to the website of metz: www.metz.de and choose english. Then go to their flash gun site, there is a manual available for this flash too. And most important of all: It's free!
Nov 16, 2009 | Metz Mecablitz 60CT4 TTL Flash
I have a sunpak 622
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
Jan 31, 2009 | Sunpak 622 Super Pro TTL Flash
Non-syncing Olympus FL-36
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 12, 2008 | Olympus FL-36 TTL Flash
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Mating Metz 60CT4 to Nikon D80 camera
The 60CT-4 was not made for digital cameras.
It does TTL on film not on CMOS or CCD sensor.
Alexander
atdlee@netzero.com
Nov 22, 2007 | Metz Mecablitz 60CT4 TTL Flash
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
5-pin TTL connector for external flash
The 5-pin TTL connector is designed to control the Olympus FL-40 dedicated flash unit (p/n 200596). To use the FL-40 with these cameras, the optional Olympus FL-CB01 cable (p/n 200 664) and FL-BK01 flash bracket (p/n 200 666) must be used. The 5-pin TTL connector can also control a PC Sync flash or strobe system by using the optional FL-CB04 flash cable (p/n 200 661). Since this type of flash/strobe is non-dedicated, the photographer will need to manually match the flash output with the camera.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Metz mecablitz 45 CL-4 TTL Flash Logo
65 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
