The tv works great. It is a tv/dvd/vcr combo set. However, the dvd player has recently quit playing any sound. The picture is clear from the dvd disc but there is no sound.
  • 4 more comments
  • jflcox Sep 27, 2009
    I can't disconnect the dvd player. It is built into the tv. There are no headphone jacks either. Any suggestions?
    Actually, the tv did have headphone jacks but there was no sound when a dvd was playing.
    The tv works great. It is a Magnavox tv with a dvd player and vcr built into the set. However, recently the dvd player has quit playing any sound. The picture is clear from the dvd disc but there is no sound. The tv model number is: MWC24T5-A
    I did not see a dvd profile in the options menu. Is it possible to connect RCA cables to the audio output on the back of the tv to the inputs on the front of the tv and recover the lost sound from the dvd player?
    I don't see sound settings in the options menu; nor do I see a dvd profile and I have looked extensively. I guess you are saying that the tv is in need of professional repair and the rca cable idea that I had will not work? If it needs professional repair, purchasing a new dvd player would be cheaper and just hook it to the rca a/v inputs on the tv because the tv audio is perfect as long as the dvd source is not selected. Remember it is a tv / dvd player / vcr combo all built into the set. Fortunately there are a/v jacks in which I could hook up an external dvd player. Do you see any problems with this solution?
    Yes, the expert's answers were very helpful.
  • 2,200 Answers
Hi
First check the sound settings in the options menu of the DVD profile to ensure that these are active and not causing the problem.
If these settings have not been changed then it seems likely that the problem is with the audio switching circuit within the unit itself. This is not a user serviceable issue and will require to undergo a troubleshoot of the main PCB by a tech.
Hope this answer has helped. Please do remember to use the rating. Many Thanks
Posted on Sep 27, 2009
  • Radio Code Pro
    Radio Code Pro Sep 27, 2009
    Hi
    If you have audio out on the back of the dvd and audio in on the TV you could certainly try this - however the fact that you have no audio from headphones with the DVD playing would indicate a circuit failure meaning it is likely there will be no Audio from the RCA out.
    There is a possibility this may work though so it is certainly worth a try!
    Do let me know how you get on.
  • Radio Code Pro
    Hi
    Yes I do understand it is a combo unit you have. Seeing as you have the auxillary inputs for another player there is no reason why connecting another DVD player should not work. DVD players can be purchased cheaply nowadays and this may well be the best option.
    This way if your TV develops other problems at a later date you will still have your DVD player as a standalone unit which can be used again with another TV. It is for this very reason that I am not fond of Combo units i.e. when one component gives trouble it in turn effects the whole unit.
    When you purchase your components as standalone units - the problem is always confined to an individual unit if and when any problems occur. This is a distinct advantage over Combos.
    I can see no apparent reason why your plan should not work unless there is an unknown problem with the inputs on the TV. If you know someone with a standalone DVD player that you could borrow it and double check your TVs inputs before purchasing your own. It would only take a few minutes to do this and then you will be sure that all is well.
    Hope you get it sorted soon.
    Thanks for using FixYa and do remember to rate my answer. Many Thanks.
  • 3,267 Answers
The sound circuit has konked out or the lens is unable to split audio & video signal, since DVD format is diff. from that has to read only one signal i.e. audio.If there exists a socket for plugging in headphones, do so & check if sound is coming through. If yes, then a connection must be loose & has lost the connection to its next part in the sound amplification circuit. Also disconnect the player & plug in the TV signal cable directly to the TV set to check if the TV is sounding normally. Then you can be sure that the sound amplification & not the pre-amp, is to be repaired/replaced..................sodeep
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
Vcr only plays in black and white
Hi Ryana,
Check if the recorder is set to output in 'S-Video' or 'SuperVideo' mode, if your TV doesn't understand S-Video you'll get a grainy B&W picture. The VCR should be set to output in PAL for the UK and most of Europe.
Hope this helps
Andy
Jun 26, 2008 | Philips DVP620VR DVD Player/VCR
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Help me connect my components...
on the remote it should say menu it would probably be in the pitcher side set it to 4.3 or 4.5 or so on it is the setting you need ok hope that help
Jan 03, 2008 | Akai LCT2785TA 27 in. LCD Television
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
DVD Player Subjective to Netflicks Discs...
Glad you have the problem straightened out.
Have a great week
Ed
NC Electronic
Mills, Wyoming
Jan 10, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
