Question about Nokia 6500 Slide Cellular Phone
Pls i want to change the lcd of nokia 6500 but i could not get to the lcd to be replaced due to screw driver size. could you tell me the type of screw driver to use and procedure.
    Problem Solver:
  • 7 Answers
Its not a normal screw driver
its called a T6 or T5, the nokia 6500 slide uses a T5 screw driver.
Posted on Oct 19, 2009
  • 832 Answers
You must have the cell phone screw driver that you can
buy at the hardware stores, before you can do the job.
Posted on Sep 27, 2009
Forgot my security code {nokia 6500s} help pls
The default Nokia security code is 12345 unless it was changed.
Apr 08, 2012 | Nokia 6500 Slide Cellular Phone
Hello, Can you tell me how to get inside my nokia 6085 cellphone screen so I can clean all the dust of the inside of the screen. Thank you Robyn
To clean the dirt and rust on your lcd screen is so easy to do.
Here are the Tools to be use,any improvise tool can do.
* you can use small,precision flat screw driver the same as a swiss knife or any.
* a clean clothe
* scotch tape
* a T6 precision screw driver or any tool that can remove the screw,even a sharp knife or swiss knife can do.
Here is the procedure on how to disassemble the upper block portion.
1. remove the battery first before dismantling the upper block portion to avoid electro-static components on your mobile, might result to a short circuit due to the used of metal tools that contacts some parts of it.
2. now at the back portion of the upper block, you can see a margin located at the bottom part centered,lift up the back cover using the flat screw driver all through the sides, some area is to hard to release because there are some hidden clips inserted.
3. upon removal of the back cover of the upper block, you can see a flex connection on the left side bottom,gently pill it up or pull the plastic to remove from the board connector.be care of that flex connector cause it is just only may from a thin,plastic parts and easy to be teared.
4. Now you can also see 4 screw, release the screw using a T6 presision screw driver then place it to a safe area, might be lose due to its small size parts.
5. carefully lift up the entire module (the board with lcd) then place it on a safe area cause the lcd might be broken when dropped off.
6. using a clean clothe, wipe the glass type cover of the housing which dust and dirt is located.as well as the lcd.
7. to remove some marks or fingerprint marks on the glass cover or lcd, use a scotch tape then place it all over the panel of lcd and glass cover by pulling up and down.
8. now assembly it and be guide and look forward for the pattern on how you dismatle all parts and position.
Take a look at some scene here on this video (just be guided on the particular portions)
Hoping this procedure is clear enough for you.. Thank you for visiting fixya...
Jul 02, 2011 | Cell Phones
White screen 6500 slide I need help plz I've
Display can be Lcd,Flex connector,board connector,display IC etc.
If you already try at least 2-3 lcd, take another step of replacing flex connector 2-3 also, to make sure that the item you bought has no defect.
If this 2 parts didn't make it, check the board display terminal if its clean and corrosion free. resoldering each terminal may be helpful enough.
last option is replacing the display IC, it will serves as a fuse of it, a clystal square type that generate current to be able to display on screen.
Jun 28, 2011 | Nokia Lands Phones
Hi i haave 6500c,but it show white display.i change also new lcd but same problem pls tell me about this problem.
as my knowledge its internal IC problem. Not display side issue. there is 2 small IC with 6 to 8 pin ( for power operation of LCD ) may be damaged. replace it with temperature control solder iron. It will solve your problem and this is cause to big shook or vibration.
Dec 06, 2010 | Nokia 6500 Classic Cellular Phone
6500 slide
on the main screen type *#7780# then put the security code. hope this help you
Apr 14, 2010 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide display 4900 problem
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Sep 16, 2009 | Nokia 6500 Slide Cellular Phone
Nettwork unlocking nokia 6500c
hi i have nokia 6500 classic can u tell me how to i unlcok its on vodafone plz send me Restriction code network 356381029185307
Apr 04, 2009 | Nokia 6500 Classic Cellular Phone
Nokia 6500 classic Need country code
oh noes! type in *#1337# and then turn the phone off with the numbers still displayed. Then wait for an hour, and turn it back on. It should show a manufacture's option to change the global location for the phone. If it doesn't work, try it again and wait for two hours, and so on, before turning it back on. Hope it helps :]
Jan 26, 2009 | Nokia 6500 Slide Cellular Phone
Unloching nokia
Trying using the Software Update Application via your USB Cable & PC.
If you still experience the white screen problem, take it back and demand a refund or a replacement phone other then a 6500.
The 6500 has endless problems, and it seems that the White Screen is through a Manufacturing Fault.
Add to that, the fact that due to placing the antenna on the bottom side of the handset, is why they are so **** when it comes to poor signal.
just type in the words Nokia 6500 white screen on google, and you'll see that your not alone on that situation
Sep 01, 2008 | Nokia 6300 Cellular Phone
Pls help me out
Is this phone water damaged? If other functions are ok then your lcd may be displaced. If you have a proper screw driver you can open your phone, clean the connector and put the lcd correctly and assemble your phone, it will work again.
May 20, 2008 | Nokia 6288 Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
113 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
