Question about Diesel Case 530,570,630 Tractor Piston & Sleeve
How do I time an injection pump on a case 188 diesel/
Find TDC on the compression stroke, there are timeing marks on the drive shaft for the pump, it well only fit one of two ways. make sure that the two dots on the shaft and the pump match up,that schould do it
Posted on Jul 17, 2011
Hi, I had my fuel pump on my case 2294 done and i am currently struggling with the timing does anyone know at what degrees it needs to be set at
diesel pump timing varies with makes of engines
call the case service center and get the degrees for the injection timing
Apr 19, 2017 | Cars & Trucks
How do I install diesel fuel injection pump
Diesel injection pumps need to be timed to the engine. You have to set the engine to top centre on number one cylinder and compression stroke, then set the injection pump to number one, should be a line to line up or a pin to install to set pump to number one. Then install the pump and bolt it on
Dec 13, 2015 | Diesel Garden
How do i time injection pump
injection pump timing is critical on a diesel. Take it to an accredited diesel specialist and he will have the necessary equipment to do the job right.
Mar 19, 2014 | 2000 Ford Focus
Ford ranger 2.5 diesel pump timing marks
Could you give me injection pump gear pump timing for a Ford renger 2.5 diesel 2007 please
Apr 29, 2012 | Cars & Trucks
Transit pump code p0216 how can i fix this
P0216 DTC - Injection Timing Control Circuit Malfunction and this means the diesel fuel injection pump has a timing failure. This could be that the injection pump timing needs adjusted OR the failure is internal to the injection pump and therefore non-adjustable.
NOTE: If your vehicle is a Dodge Ram with Cummins engine then be aware that fuel delivery problems frequently cause this code. Prolonged fuel delivery problems can cause injection pump failure!
Symptoms of a P0216 DTC may include:
Low power
Crank, but no start
Hard start
Displays an intermittent stumble or miss
Engine may start and then stall
Engine may appear to drive fine but surge at idle
The most frequent cause of this code is a bad injection pump due to poor fuel delivery. Fuel delivery problems could be:
A plugged diesel fuel filter
An in-tank blockage
Air in the fuel due to a cracked in-tank fuel ine above the fuel level
Bad transfer (lift) pump
Injection pump out of time
Possible Solutions: First, simply check if your injection pump timing is adjustable. If so, check the timing and adjust if necessary.
If you think that you may have a fuel delivery problem, then check the lift pump operation. On Dodge Ram with the Cummins engine, the lift pump should produce about 45 oz of diesel in 25 seconds of operation. This can be performed by disconnecting the fuel hose from the injection pump and pumping the fuel into an approved container. Bump the engine over but do not start it. Then the lift pump will operate for 25 seconds. If the fuel is aerated, then check/repair fuel line and recheck.
With the fuel hose connected the fuel pressure should be 10psi. If the fuel delivery tests fail, replace the diesel fuel filter and recheck.
If it still fails then verify there are no restrictions in the fuel tank
Then replace the lift (transfer) pump. IT SHOULD BE NOTED that if this code surfaced after a routine fuel filter replacement or if you have any of the above symptoms after routine fuel filter replacement, then suspect the fuel transfer pump. This occurs because even a weak transfer pump can still provide enough fuel for the engine to run. But when the fuel system\'s prime is lost due to fuel filter replacement, it may not restart again without fixing the fuel delivery problem.
If you found your injection pump to be bad, the lift pump should be checked for operation to protect the new injection pump. This is because weak or low output from lift pump are common cause of injection pump failure. There are some aftermarket kits that can be purchased to warn the operator when the fuel pressure/volume drops to level that could damage the injection pump.
Hope this helps (remember to rating this free answer and leave a testimonial comments).
Oct 11, 2011 | Cars & Trucks
Timing marks trooper 1985 mod dlx turbo diesel
Refer to Figures 1,2,3,4 when performing 17-step timing procedure for 1981-1985 Diesel Engines.
Fig 1. Injection pump and camshaft alignment marks - Diesel engine.
Fig 2. Removing the timing belt holder - Diesel engine.
Fig 3. Injection pump alignment marks - Diesel engine.
Fig 4. Tensioiner Pulley Bolt Sequence - Diesel engine.
Procedure - Timing Belt replacement.
1. Disconnect the negative battery cable. Drain the cooling system.
CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
2. Remove the timing belt cover. Remove the injection pump sprocket flange.
3. Using a prybar, remove the tension spring from the timing belt tensioner.
When removing the tension spring, avoid using excessive force for the spring may become distorted.
4. Remove the tensioner pulley bolt and the pulley.
5. Remove the timing belt and discard it.
To install:
6. Rotate the crankshaft to bring the No. 1 piston to TDC of the compression stroke.
7. Align the timing marks on the injection pump sprocket with the camshaft sprocket; the marks must be facing each other.
8. Using a new timing belt, install it in the following sequence: crankshaft sprocket, camshaft sprocket and the injection pump sprocket; the slack must be between the injection pump and camshaft sprockets.
9. Install the tension center and the tension pulley so the end of the tension center is fitted against both pins on the timing pulley housing.
10. Hand tighten the nut so the tension pulley can be rotated freely.
11. Install the tension spring and semi-tighten the pulley nut to 22-36 ft. lbs. (30-48 Nm).
12. Rotate the crankshaft 2 full turns clockwise to seat the belt and further turn the crankshaft 90° beyond TDC to settle the injection pump.
13. Loosen the tension pulley nut to take up the timing belt slack. Tighten the tension pulley nut to 79-94 ft. lbs. (108-128 Nm).
14. Install the injection pump sprocket flange; the hole in the outer circumference of the flange should be aligned with the triangular timing mark on the injection pump sprocket.
15. Rotate the crankshaft 2 full turns clockwise to bring the No. 1 piston to TDC of the compression stroke. Make sure the triangular timing mark on the timing sprocket is aligned with the hole in the flange, then, measure the timing belt tension; it should be 33-55 lbs.
16. Install the timing belt cover.
17. Connect the negative battery cable.
Jul 04, 2011 | 1995 Isuzu Trooper
Diesel Injection pump for Jeep Cherokee
The diesel injection pump is responsible to deliver the diesel to the engine and to control the speed of the engine by matching the fuel output requirement of the engine. You can get Diesel Injection pump for all models especially for your Jeep Cherokee at http://www.dieselpartspros.com/diesel-injector-pump.asp
Jun 03, 2011 | Jeep Cherokee Cars & Trucks
2000 dodge ram diesel 2500 . What is a fuel injection pump mechnical failure? a fuel valve feedback circuit?
This usually happens when the lift pump gets worn and fuel pressure drops below 7lbs and the injection pump has to work harder by pulling in the fuel and will destroy the pump,your is probably a vp44 fuel injection pump it needs replaced and they are expensive 1200.00+ but also change the lift pump or change to a fass fuel system,if the lift pump went out and you replace the injection pump it will ruin it in a short time.
The injection pump is not an easy job to change or for a novice mechanic as it has to be set in time with the engine at top dead center,and then the whole fuel system needs to be bleed of air.
May 21, 2010 | 1999 Dodge Ram 2500 4WD
Diesel Case 530,570,630 Tractor Piston & Sleeve Logo
969 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
