Question about Sony Ericsson W850i Cellular Phone
Lost buttons on key pad can they be replaced or repaired
  • 832 Answers
Of course, you can change the keypad easy. You can
buy an existing keypad from the your nearest cell
phone dealer. Send your e-mail if our solution did solve
your problem.
Posted on Sep 27, 2009
The touch pad works, the right mose key works, but the left mouse key will not work
the problem is with button of left key u have to repair it by opening the plastic body of the touch pad of the laptop there is a switch which has to be replaced if u can do it fine or visit a service technician
Dec 07, 2010 | Computers & Internet
Tip
Fault Codes for Admiral Range/Stove/Oven
There are many fault codes for different ranges, ovens and stoves. These also are different for each manufacturer or brand. To see what the fault codes are and what they mean for the Admiral brand you can check this chart. It also will give you a short explanation and repair for each code.
Some of the repairs are simple and some of them are much more difficult.
Most parts are easily bought online. Check the link below to another tip I wrote about how to buy parts online.
Fault code What is wrong What to check or repair
F1 Defective touch pad or Replace touch pad or clock assembly
Membrane this also can be called the ERC
F1 Watchdog on board Replace the touch pad or ERC
F2 Oven too hot Replace the relay board or oven temp
sensor
F3 or 4 Open or shorted oven Replace oven temperature sensor
Temperature sensor
F5 Hardware and watchdog Replace clock assembly or ERC
circuits disagree
F6 Missing AC signal Check for proper voltage
F7 Function key shorted or Un-stick button or replace touch pad
stuck button /ERC
F8 Analog/digital trouble Replace clock assembly/ERC
F9 Door latch trouble Check door lock circuit or ERC
F0 Function key stuck Replace touch pad or ERC
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
on Feb 18, 2010 | Ovens
The scroll button thing on my zune won't work. I can't change songs or change the volume. How do I fix it?
Hi if your key pad is not working you will have to replace the key pad. Thats the only solution I know of.
If you need more help, parts or repair services you can go to my repair service web page at firehouse7777.weebly.com and find info to contact me if needed. thanks
Nov 30, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
Jul 28, 2010 | Computers & Internet
I have a Verizon Moto Q. The buttons are not working properly. When I hit the start button, back, the arrows, or center select button, mail button and certain letters it just enters numbers or letters and...
Hi, from the question you posted, there are three likely problems to the phone. One it's either the key button pad is bad which needs to be replace, the interface of the key button pad is dirty which needs to be cleaned, or the glass I.C which controls the key button is bad which also needs to be replaced.
But i think what the problem is the cleaning of the key pad button interface because the buttons are working but they only misrepresent whatever function you try to perform on the phone.
You just need to get a mobile phone technician or an electronic repairer around you to help service and clean the board and key pad button interface, and the phone will start working fine..
Take care
Mar 26, 2010 | Cell Phones
Get code F2 on display, intermittent
Try this :) press and hold one of your push buttons on your key pad for 1-3 min and wait for the error code. if you get a F2 Error then your problem is a intermittent stuck key on your key pad and you will need to replace it to repair the problem.
Oct 06, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F7 fault code on the Jenn-air W30400W
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps .
Mar 04, 2009 | Ovens
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
Key Pad buttons require more force to accept the input - loosing memory!
I have the same phone with the same problem and didn't want to part with it either. The cause of the problem are skin oils that seep down the rubber keys, and through slots at the base of the molded pad, thereby interfering with electrical contact. There is a vendor on ebay that sells a tape like pad with larger contacts that solves the problem perfectly. Go to ebay and use the following search term (I know this isn't the same model number, but its apparently compatible) :
Panasonic KX-TGA230 KX-TGA270 KX-TGA230B BUTTON FIX
The price is 5.95 including shipping. The repair pad will come with an instruction sheet, or you can go to the website on the instruction sheet and download about a 40Meg video file that shows you exactly how to make the repair. My phone operates with a nice light touch now that its fixed. Good luck.
Aug 24, 2008 | Panasonic KX-TG2383 Corded Phone
Sony Ericsson W850i Cellular Phone Logo
23 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
