Question about HP P2360AA Keyboard/Mouse
My Hp keyboard keeps typing repeatedly and its not just one key. after a while it stops, and another key is repeatedly typed. its getting irritating and i need help. I have tried reinstalling the drivers but the problems keeps surfacing. This just happened today, like 2 hrs ago
  • 832 Answers
Run the anti virus program in your PC. If this will won't
help, then, please reformat your PC operating system.
Posted on Sep 27, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How to fix sticky keys
    You must increase the leadtime before Windows considers your keeping a key pressed down means you want to repeat it.
    Open Keyboard Properties by clicking the Start button , and then clicking Control Panel. In the search box, type keyboard, and then click Keyboard.
    Under Character repeat, move the Repeat delay slider to the right to increase how long you must hold down a key before the keyboard character repeats, and then click OK.
    Jul 24, 2014 | HP Pavilion Computers & Internet
    My keyboard will not type a double letter or backspace more than once without stopping first? Do you know why?
    Disable Filter Keys in Windows 7 and Work.If Filter Keys has turned on in Windows 7 and your keyboard is no longer responding as you would like, follow these directions:
    1. Click Start
    2. Click Control Panel
    3. Click the Ease of Access heading.
    4. Click Change how your keyboard works.
    5. Remove all the check mark in the box next to "Turn on Filter Keys".
    Enjoy :)
    ~ Vikrant (India)
    Dec 09, 2010 | HP Computers & Internet
    When I type suddenly I am thrown to the middle of my current sentence I am writing or on to another paragraph below or above. Extremely irritating and is stopping me from working as efficiently as I...
    Are you on a laptop or desktop? PLs be more specific.......What version windows are you running, what type of keyboard (if desktop) and is it wireless or not?
    If you are on a laptop your are bumping the touchpad
    pls respond promptly
    May 26, 2010 | Acer NSK8458AN Keyboard
    I have an HP Pavillion ze5300 laptop, and most of the time (15 out of every 20 minutes about) the "]" key keeps repeating. Sometime I can type if I am pressing the backspace key the entire time, but that...
    It sounds like you need to replace the keyboard. Replacing the keyboard is not difficult or you can take it to a repair center. Parts can be ordered online from HP or aftermarket vendors.
    Dec 09, 2009 | Saitek Executive PZ18AU Keyboard
    Question mark key and quotation marks acting up
    It may be a defective keyboard. Check to see if any keys are sticking like the Shift key.
    Feb 01, 2009 | HP Pavilion DV6700Z Notebook
    Dell lap top keyboard keys "s" and "a" are messed up
    Ok, first try looking under the A,S & D keys and see if there is anything stuck in there by those keys.
    You can then try blowing with mouth or a can of pressured air to clean it out.
    If nothing stuck in there, does the keys feel sticky, if so, then there might have been some liquid spilled on it. Try to dry it out with a hairdryer set on medium to see if that helps.
    keep me informed
    Dec 13, 2008 | Dell Inspiron 6400 Notebook
    Wireless keyboard keys sticking
    on most keyboad you can take of each key. Try to get a flat head screw driver and pop it of with some force. You then can clean the keys. If this does not work you might need a new keyboard. Do not use water (or very little)
    Sep 20, 2008 | Dell Latitude C640 Notebook
    HP P2360AA Keyboard/Mouse Logo
    532 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
