Question about Radio Shack TRC-447 CB Radio
Trc 447- has power but no channel switching
Well my cb radio used to work. I'm still able to get power but it wont let me change channels. What could the problem be?
  • Anonymous Jan 07, 2008
    I have a problem with the TRC-446 , I get no sound thru the speaker and when I plug an external speaker still no sound , but signal meter works and so does transmitter .
    Novelist:
    Champion:
  • 211 Answers
Do you have your channel switch ( the first switch to the left as you look at the front of the radio ) switched to a normal position ? If so, you may have a bad switch. Another problem could be a bad PLL Chip which is the frequency control device. I hope this helps.
As for the Guest post on the TRC-466, I would install a new mic first, as if there is a problem in the mic or cord, it will cause the sound to quit. Other than that, it would be a good guess that the audio chip is bad. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Channel will not change on my radio shack cb trc-231
check to see if the channel 9- 19 switch it set on those channels.
Apr 26, 2014 | Radio Shack Lot Of 3 Walkie Talkies 2 Way...
How do you get more channels
you have to jump the pins on the ICupd789166. you may want to have a tech do it for you.
Nov 01, 2013 | Radio Shack TRC-447 CB Radio
Add more channels
not worth the time or effort to do on this radio. years ago when it was the thing to do , yes but not today when you can get a radio with those channels already installed .
Jan 24, 2013 | Radio Shack TRC-447 CB Radio
I was wondering what is the best settings and what can i do to make sure im getting full use of my radio shack trc-44
HI, my name is John. The best way to do that is to get someone on the other end of you to give you a radio check, go to channel 19 and ask for a radio check, ask them how it sounds and they and you can go from there....good luck...hope this was helpful..
Sep 02, 2010 | Radio Shack TRC-447 CB Radio
Radio shack trc-447 cb. no controls function, radio turns on. Channel displays 8. switches do nothing,
The units have a reset code that protects the PLL brain from damage from voltage spikes. Ship it in and I'll get it back to normal function for you, providing the PLL has not been damaged.
Thanks,
Dodgem
www.Dodgem250.com
Feb 12, 2010 | Radio Shack TRC-447 CB Radio
Tunning the antenna on radio shack cb trc-447
After installing the antenna, follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
The ideal standing wave ratio (SWR) is 1:1, or a meter
reading of 1 on the SWR meter's top scale. A SWR ratio
of 1.5:1 to 2:1 is excellent for most mobile CB antenna
applications.
Check the SWR on Channel 1 and Channel 40
If the SWR is higher on 1, make the antenna longer
If the SWR is higher on 40, make the antenna shorter
Most antenna's are adjustable. Make small adjustments at a time.
Oct 10, 2009 | Radio Shack TRC-447 CB Radio
When mic is keyed, TX light illuminates but power meter does not
make sure your s/rf switch is in the right place on the radio is the most common problem i have found
Feb 05, 2009 | Radio Shack TRC-447 CB Radio
RADIO SHACK TRC-447
A number of things....faulty speaker (you can scratch test this with a torch 1.5 volt cell....cell pos goes to 1 speaker terminal
and cel neg goes to other speaker terminal..you can conect it any way around with flying leads from the cell...just keep touching the terminal with one flying lead...you will hear a scratching sound in the speaker) have your mike checked...test the tx/rx relay on the circuit board for tx/rx switching, or, a failed
driver transister in the output stage....the list is many
Cheers flyingfox@people.net.au
Jun 21, 2008 | Radio Shack TRC-447 CB Radio
Radio shack mic with up & down ch.
use this one http://www.download-streaming-video.com/radio-recorder/
Apr 16, 2008 | Radio Shack TRC-447 CB Radio
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Shack TRC-447 CB Radio Logo
155 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
