Question about Olympus Camedia P-10 Thermal Photo Printer
It wont print, the access and paper lights are flashing simultaneously and I'm getting told the error 21h has occurred
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Red on print is coming out pink
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not all the colors print
Best of Luck
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Poor black print quality black prints greenish grey
Best of Luck
Nov 16, 2009 | Office Equipment & Supplies
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
Possible causes are as follows:
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
Apr 21, 2008 | Canon PIXMA iP1600 Printer
According to the Manual, when both the Access and Paper light go on simultaneously, there is a paper jam. Check to see if there is, also check to make sure the paper is loading from your tray correctly. You have the paper face down right?
Turn off the printer after you fix he jam or paper, and turn back on before you try to print again.
Hope this helps
Oct 21, 2007 | Olympus Camedia P-10 Thermal Photo Printer
Hp 1350 all-in-one
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
Sep 06, 2007 | HP PSC 1350 All-In-One Thermal Printer
Olympus Camedia P-10 Thermal Photo Printer Logo
119 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
