Question about Plumbing
I need to replace the front & rear bearing on my Davey 95D pump Ineed to know the bearing part numbers. Thank you Glenn
  • 832 Answers
You can go ahead and disassemble your Davey pump.
You can take the bearing off. On it, at the side, you will
find the bearing number (could be 6001, 6002, 6201, etc.) etched. You can buy the replacement bearing from
hardwares near you.
Posted on Oct 26, 2009
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
Ac pump noisy, mech says bad bearing, but can't get part
look on ebay and aadvaced auto make sure u cant get bearing ok i neede done paid 25 on ebay 100 labor install it new ac on advced auto u can see cheaper find local guy install it ok
Oct 11, 2008 | 2003 Chevrolet TrailBlazer
I need the shaft and bearings
Do you mean Shaft SEAL?
and MOTOR Bearings?
You will need to know the make and model of your pump, for the proper shaft seal, since that has to do with matching correctly to the 'Wet End'.
And you will need to know which bearings are in your Motor, to get proper replacement.
Amazon com Pool pump shaft seal
and for for the bearings...
usually two different sizes, one for the front, and another for the rear. It's a 4 digit part number, but the 1st digit is usually a 6, and it's not used when requesting a motor bearing, Why? I don't know?
So 6203 is requested as a 203 bearing. There are 304's, 294's, etc.
Browning Motor Base
Apr 22, 2015 | Pool & Spa
Davey pump parts diagram
Davey makes great pumps but they make more then one model. More information is needed such as model number.
Jul 17, 2013 | Plumbing
I am trying to replace the passenger side hub and bearing,before i tear it down i need to know if the bearing is just pressed onto the new hub and then the whole assembly slides onto the splined end of the...
Hello texasjagfan: My name is Roger and I will help you. The front hub bearings are press out bearings and you will need a press in order to change them. You will need to remove the front spindle to gain access to the bearings.You also will need an alignment when finished replacing the front bearings. The rear bearings are a hub and bearing unit.
Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Aug 18, 2011 | 2003 Chrysler PT Cruiser
Ineed to replace rear wheel bearings
Why do you say that? Did a professional bike technician tell you? You may be better off buying a new wheel unless you have the tools and the know how to rebuild your rear hub.
Sep 27, 2010 | Huffy 26in Ladies Sante Fe Cruiser Bike -...
Ineed to replace rear shock on rsv 2001.
Both Ohlins and Works performance make shock/spring replacements for the Venture, an internet search should get you a number of sources.
Apr 26, 2010 | 2001 Yamaha Royal Star XVZ 1300 A
NEED TO REPLACE WHEEL HUB BEARING OR ONLY THE BEARING
Front Is pressed into hub & knuckle.Rear is a Hub/Bearing Assembly held in by 4 10mm bolts.Will need to pound out with hammer in rear after bolts come out,lots of rust holding them in.Front Knuckle has to come off,Then a large Snap ring,then press out the hub,then the wheel bearing.Hope this helps
May 19, 2009 | 1996 Saturn SL
Whirlpool duet washer tub bearing
wow ,,that unit must sound like a jet ..this is a job,,i can talk you though but i cant tonight,,if you can wait i will help tommorow at 6 after work..if you need a little head startgo to cematters.com
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bad Drum bearing need part number
Im sorry, but the rear bearings (unless its changed just recently) is a non servicable part, you will have to replace the entire rear tub section. Also, most of the time, you end up having to change the inner tub as well, the shaft is usually wore out as well.
Oct 30, 2008 | Kenmore 43142 Front Load Washer
Plumbing Logo
691 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
