Question about Nokia N95 Cellular Phone
How to set a gprs,mms settings on n95y china phone
How to set a gprs,mms settings on n95 china phone with dns not a proxy....
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 | Cell Phones
I CANT SEND MMS IN MY K770I
U need to activate mms service by calling ur service provider and these are the settings fo the same.
Press “Menu” and go to “Messages”
Select “Settings” and select “Multimedia messages”
Select “Network settings”
Select “Options” and select “Add new”
Enter the profile name as “service MMS”
Press “Ok” and select “Options”
Go to the “Settings”
Enter the details as follow:
1. Homepage: Define homepage here.
2. Bearer: GPRS
3. GPRS settings
APN: Define acess point name here.
User ID: <blank>
Password: <blank>
4. Proxy settings:
Proxy settings: On
IP address: Define Ip add. here.
Port: 9210
5. DNS settings: <Leave it as default>
Press “Ok” to save the settings and return to the main settings and select ‘Activate”
MMS configuration completed
Good luck
Jun 30, 2010 | Sony Ericsson K800i Cellular Phone
How to open the gprs/ mms of china phone?
you just have to activate GPRS/MMS services on your phone. Then you need GPRS/MMS settings on your phone. Please call your service provider and get APN, IP Address, proxy port and homepage from them and configure the settings manually on your phone as chinese handset do not support automatic settings.
May 21, 2010 | Cell Phones
Nokia phone wont connect to the GPRS
Creating Data Accounts
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Data Account: GlobeGPRS (this data account is the one you have created)
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
May 06, 2009 | Nokia 5310 Cellular Phone
Can not send or receive multimedia messages.
Maybe internet is shut off on your phone?
Here are the internet settings for Cingular: Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
and T Mobile: Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
and Fido: Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
and Rogers: Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Feb 19, 2009 | LG Shine KE970 Cellular Phone
How can i activate GPRS and MMS setting for my china mobile phone
hi there,
here i post some procedures you can follow for activation your GPRS and MMS.
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text “ACTIVATE” and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: “Sun MMS”
Homepage: “’http://www.mmscenter.suncellular.com.ph”
Data Account: “Sun MMS”
Connection Type: “HTTP”
Proxy Address: “202.138.159.078”
Proxy Port: “8080”
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select “Sun WAP”, Select “Edit Profile”
Rename Profile: “Sun WAP”
Homepage: “http://www.suncellular.com.ph”
Data Account: “Sun GPRS”
Connection Type: Select “HTTP”
Proxy Port: “8080”
hope it will help you to solved your problem or still you have any question regarding on it that you can't understand you can go on this site and log on.
http://www.kokeytechnology.com/gadgets/cell-phonesmobile-phones/how-to-activate-gprs-and-mms-of-nokia-phones-powered-by-sun-cellular/
Feb 16, 2009 | Nokia 6300 Cellular Phone
How want to activated gprs/mms on my n95 china mobile
For china mobiles manuals, software and drivers check chinamanuals.com (search for your model or just ask them)
They have a N95 user manual incl. network settings for major providers for download.
Nov 10, 2008 | Nokia N95 Cellular Phone
Cellone GPRS
for getting GPRS .you should contact cellone customer care centre.they will activate GPRS in your phone.
Jun 27, 2008 | Nokia N95 Cellular Phone
Airtel live settings for china mobile
Im using china Blutooth y690 & have airtel sim but it does'nt accept the settings of airtel live pls tell me how to configure settings mannually the phone has two menus i.e. wap profile & data setting
May 24, 2008 | i-mate JASJAR Smartphone
N95 China mobile Phone
ur wrong in my n95 china mms and gprs are working properly i know its not the original one but its quite ok for me. you can even connect it to your dvd player with usb and play all the multimedia you can put on its external flash memory you can upgrade up to 8gb mem.
May 04, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
184 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
