Question about LaCie Hard Disk 750GB with Hi-Speed USB2.0 750 GB USB 2.0 Hard Drive
Bought La Cie 750GB desk top hard drive in sale. No manual. where can I download the manual?
  • 73 Answers
How do I transfer from my la cie to my computer
Remove the USB module from the LaCie Write Card and plug it into a free USB port on your computer. Your computer should assign a new drive letter to the USB module (such as D: or higher letter). In Windows use Windows Explorer (on a Mac use File Manager) and you will be able to copy files from your LaCie USB module to your computer.
https://www.lacie.com/download/datasheet/DS_WriteCard.pdf
Sep 25, 2014 | LaCie La Cie 131057 Write Card Flash Drive...
How do i transfer my data from my old la cie 80 gig 107443, to my new la cie 250 gig 300770? both boxes look the same, with the same connections [firewire, usb, 2 others].
Connect both drives to the computer at the same time. If you don't have enough USB ports, connect one to a USB port and the other to a Firewire port. Open a file management window (Explorer in Window, Finder in Mac OS) for each drive. Click and hold the left mouse button (only mouse button on most Mac models in the window for the 80 Gig drive and drag across several folders/files to select them. Release the mouse button, then click on and drag the selected group to the new drive window. When this copy operation is done, repeat with another group of files.
You could select (-A or -A) and drag everything on the old drive at one time, but sometimes the system will bog down on copying large amounts of data (greater than 4-8 GB at a time).
Mar 11, 2011 | LaCie (300770) 250 GB Hard Drive
I bought a rikiki go 500GB La cie today, and it's making zooming and loud clicking noises, what's wrong?
Your hard drive is most likely dead, you need to call the manufacturer and have them send you a replacement, the warranty should cover this.
Mar 04, 2011 | LaCie Rikiki Go Hi-Speed USB 2.0 500GB...
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
250 GB La Cie desktop Quadra drive will not mount and makes a soft clicking noise; does not show up on System viewer, only as 'unknown device' Mac Pro OS X 10.5.6 Have tried to swap out firewire cables,...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Sep 20, 2010 | LaCie (300770) 250 GB Hard Drive
Help transferring files from computer hard drive to La Cie
Well you can ONLY transfer/Move DATA as Programs and Documents & Settings and User Directories, cannot be shifted at all. So It is only the Files and Data that can be Moved off a drive. To gain space back, Right Click on the HDD, go to properties, in properties Under the general, tab the first window, select disk cleanup, remove everything in those boxes and after, that look under Tools tab, & do a disk defragment. This may get you space back. If not you may have to get a new bigger drive, and clone your old drive, then install the new drive and reinstall the Cloned image back onto the new drive?
Mar 30, 2010 | Computers & Internet
Seems to take a LOONNNNGGG TIME ready the drive...
This may be a faulty power cable - a common La Cie problem apparently. Symptoms are some power getting through so blue light flickers, clicks, does not show up on desk top. I fixed mine with a new cable.
Dec 03, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie Hard Disk 750GB with Hi-Speed USB2.0 750 GB USB 2.0 Hard Drive Logo
76 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
