Question about Cell Phones
No ring tone only vibrates when trying to change
I have just bought 2nd hand 3310 nokia new sim no ring tone only vibrates is there an easy answer ,when I try out different tones it only vibrates the beat help!!!
  • sufiakamal May 11, 2010
    GENERAL PROBLEM » Nokia Solution » Motorola Solution » Sony Ericssion Solution » LG Solution » Samsung Somution UNLOCK CODE » Nokia Unlock Code » Motorola Unlock Code » Sony Ericssion Unlock Code » LG Unlock Code » Samsung Unlock Code sufia1
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
Ringtone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan(sajwhat_2003@yahoo.com)
May 03, 2008 | Nokia 6600
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
May 02, 2008 | Nokia 6288 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Vibrate after answering
go to menu then settings then initial setup then master reset.the code is 000000
Aug 19, 2007 | Motorola Mobility RAZR V3
Ringing problem
try via using another profile in settings...option is there...else restore ur handset.....if that silent mode does not remove then do flash upgration....speaker is fine if u r able to hear the incmoing call.
Aug 05, 2007 | Nokia 6610i Cellular Phone
Cell Phones Logo
128 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
