Question about Canon PIXMA MP830 All-In-One InkJet Printer
Cannot scan. Printer is working just fine but scanner doesn't work at all. I have downloaded the new driver download but still no good. Please help.
The scan function doesn't work as I lost the CD come with Canon Pixma MX360. Is there any free download of Scanner Diver for WIN XP?
You can download the Canon printer and scanner drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Aug 18, 2011 | Canon Pixma MX360 Printer
My officejet 6210xi all in one, the scanner doesn;t work it's says need software or driver for work but web hp says the driver for this windows 7 install automatically, the printer and copier work good...
Windows 7 will just have the printer drivers for this unit by default. If you want to be able to scan, you should install the full version of the drivers which is available from the HP website. Just search for your model number, select the operating system, download and install.
Jun 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Hi. I bought an Epson Stylus TX210 printer not to long ago, and it was working fine. Everything except the scanner. so, my parents and I were trying to fix it and I'm not sure what we did wrong because...
im not sure what i'm and doesn't means
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Apr 17, 2011 | Computers & Internet
Printer works just fine, but scanner no longer has option to scan
Hi ,
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 19, 2009 | HP Photosmart C4280 All-in-One InkJet...
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
HP3055 scanner not recognizing computer
yes please goto hp.com and there will be a tab that says support and drivers click on it then click on dowload software and driver downloads and download the HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
install it and then it will work. You will get either an hp director icon on the desktop or the hp solution centre.Open either one and click on settings then point to scan settings and click on scan to setup and in the new window make sure all the listed items should be on the right hand side(if they are not then please move them manually by selecting the item and pressing the right arrow button).
There are new patches and in the downloaded software there is a software called ocr which will help it work..If this still does not work could be a problem with the scanner bulb and if ur making a scan from the adf then the adf has a separate in built scanner glass apart from the scanner bed.If this does not resolve the issue call in to hp at 1800 474 6836 and we will either replace your printer or give you and upgrade or something like that.
Jun 15, 2009 | HP Color LaserJet 2600n Printer
Scanner won't work on my lexmark 2400 series all-in-one,,,lexmark 2470
Someone will be with you shortly... [alan sixsmith] just got a new computer windows vista, i have lexmark 2450 printer scanner, printer works fine but i cannot scan or open the all in one centre, i have downloaded the latest drivers, please help
[Patricia] Welcome to Lexmark Chat Support.
[Patricia] Click on Start > Computer and open the C: drive and look for folder named drivers.
[alan sixsmith] yes iv'e done that what next?
[Patricia] Double click on Drivers folder > Printers folder > 2400 folder and look for a folder named Application.
[alan sixsmith] found it, now what?
[Patricia] Open the Application folder and double click on the setup file with the icon of a CD.
[alan sixsmith] done that. now what?
[Patricia] Continue with the installation by following the instructions on the screen.
[alan sixsmith] patricia your an angel. i'd kiss you if i could. a very happy new year to you and yours.xxxx
[Patricia] That's great, it worked!! Thank you for contacting Lexmark Chat Support. Have a GOOD DAY and HAPPY NEW YEAR as well
May 11, 2008 | Office Equipment & Supplies
HP c4280 All in one printer, scanner, copier.
I visited the HP Support site and downloaded the Uninstaller and then the Installer. It took about 90 minutes but has cured the problem completely. I also made sure all drivers were up to date from the HP site check.
Apr 11, 2008 | HP Digital Printers - Hewlett-Packard...
Got new computer and now my printer will not scan.
If you cn copy then the Scanner and Printer both are fine. The only thing you are missing is the Scanner driver/utility. Install the same from the Driver Disc you got with the Printer and your problem is solved. If you don't have the same download from the manufacturers site.
Feb 04, 2008 | Lexmark X5150 All-In-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
