Question about D-Link DIR-300 Wireless Router
When I go through the installation on the install cd, it says error 322 and can't find the router. Its connected as described in the install instructions, what should i do? I'm going to use the DIR-300 with my old DSL-520T router as a base but I haven't connected the DSL-520T to the DIR-300 yet.
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Sep 29, 2009
How to fix error 322 on linksys wag120n
getting ip starting 169.x.x.x ... cannot access router config page. Even reset don't work
Dec 03, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
Solution for error 322
From the computer you are trying to configure the router from. Make sure you have an ethernet cable plugged in from the computer to one of the four numbered ports. You do not want one plugged into the wan/uplink port, this port is to be connected to your cable or dsl modem. Also open a command prompt, press the windows key and type "cmd" <enter> then type "ipconfig" <enter> scroll up and look for an IPv4 address it should start 192.168.x.x. If it starts with 169.x.x.x then your computer did not aquire an IP address via DHCP. If it shows as 169.x.x.x type "ipconfig /renew" <enter>. If it tells you, you don't have permission click windows key > All Programs > Accessories, right click on "Command Prompt" and click "Run as Administrator and repeat the last step.
Comment back if you need more assistance.
Nov 20, 2011 | Cisco Linksys WRT54GS2 Wireless-G...
I am trying to install a WRT54GS Linksys wireless router, on my desktop, but when I get to step 4 on the CD, it says "waiting for router", but after five or so minutes, an error shows up saying ERROR 322. ...
It's possible.. try using LinkSys "Live Chat" if the online help or CD is not getting the job done for you. The support people there should be able to quickly identify the cause of the 322 error.
LinkSys used to have 24/7 telephone support, but that is gone. The Live Chat is the closest thing you're going to get to that.
Sep 08, 2010 | Linksys Wireless-G WRT54GS Router...
I receive the 322 error when I´m trying to install my new WRT160N v3 Router, by Cisco.
I think you are trying to install the router using the CD. This CD has a bug. Even if your computer is connected to the router , it will say the computer is not connected to the router and it will give you error 322 or 321.
You can install the router without CD also.
Make sure that your computer is able to go online through the modem only.
connect the computer and the modem to the router and open the set up page of the router.
On the set up page you can change the settings of the router according to ISP.
Click Here for step by step instructions
Feb 01, 2010 | Linksys WRT160N Wireless Router
No connection
Are you trying to install the router using the set up disc.
Some times you get the error 322 , that shows the computer is not connected to the router ( even if it is connected).
You can set up the router manually without the CD.
First reset the router for 30seconds, then unplug the power to the router and plug it back in.
Wait for a minute and then try to set up the router.
Click Here for step by step solution
Nov 11, 2009 | Computers & Internet
Error 322
When you try to set up the router using the set up Disc, sometimes you will get this error 322. This error says that there is hardwired connection between the router and the computer. Even if you connect the cable between the router and the computer , you will get this error message.
You can try to set up the router manually. It is easy.
Nov 01, 2009 | Linksys Wireless-G WRT54G Router
Error code 322 cannot find router, after following installation intstructions.
Try manually entering your setup information (login) for your router and see what happens. Don't use the auto configuration wizard..
May 12, 2009 | Linksys Wireless-G Broadband Router
Wireless router not communicating with computer
Dont run the CD. Connect the Wildblue to your router via the INTERNET PORT then your computer to ports 1 2 3 or 4. Turn off the router wait 10 seconds then turn it back on and restart your computer. you should be online. you dont need to install the router using the CD.
Dec 26, 2008 | Linksys Wireless-G WRT54G Router
Error #322
Try cleaning the "rollers" in the track where the paper feeds through. Look for small pieces of paper that may be logged where you can't readily see them. Look carefully. Once you clear the paper path it should work.
Dec 05, 2007 | Office Equipment & Supplies
D-Link DIR-300 Wireless Router Logo
212 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
