Question about Intel Motherboard
System can't bootup any cd or dvd
I am using window xp service pack 2. Motherboard gigabyte. Recently i am facing a problem that any bootable cd or dvd will not boot. I reset in bios cdrom in first and dvdrom in second but still cd not bootup. When windows stars it recognise cd only problem is not bootable. I need to install xp.Can anyone please tell me the solution of this problem. I will be glad.Thanks
    President:
  • 1,126 Answers
Do you have a Win98 install CD? If yes, you should be able to tell it to boot with CD-ROM support.....then use xp disk to load or install your OS.......I'm doing that right now on a different system. It will format your drive first....which takes a looooooooooooong time, however, it is worth it.
Posted on Sep 27, 2009
How to format my compaq pressario cq40 604tx laptop with xp
hi
Boot from your XP install CD and select the option to format the C:
drive. If you don't have an install CD, use the "System Restore" CD or
DVD that came with your system. These restore your system to factory
settings. There're still other ways to format your C: drive, but
without either an install CD or restore one, you'll end up with an
unusable system after formatting the C: drive.
If you use the XP install CD, you'll need to be SURE you have all the
drivers for things like your DVD/CD drive, NIC, video, audio, modem, etc.
Jul 02, 2010 | Microsoft Windows XP Professional With...
How to make bootable disk with win xp.iso format?
to answer the first question an Iso file can be burned to disk using the iso
burning function that comes with most burning software. if this file is an operating system then it would automatically be burned as a boot disk and nothing else would be needed. However if this is say service pack 3 and its an iso format then even though your burning it using an iso function it would just be service pack 3 and nothing else a none boo table disk.
Dec 01, 2009 | Microsoft Windows XP Professional
Problem loading XP Serve Pack 2 in Gigabyte 8I845GVM-RZ
I know this may sound mundane, but did you load the correct set of windows drivers for the Intel 845 chipset? I mistakenly loaded the Home drivers onto a unit I tried to install Pro on and I got all sorts of errors.
Mar 26, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Needs video drivers for GA-k8vm800m
http://www.driverstock.com/download-GigaByte-GA-K8VM800M-driver/30-9-8096/index.html
Feb 26, 2009 | Gigabyte GA-K8VM800M Motherboard
Problem in xp installation
hello,
If you have cd utility to motherboard, then insert it to the CD ROM and install all the driver so that everything were fine.
If you hve no cd utility then you can download it from here:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1605
may this help,
melnavz
PS:
pls do not rate me if my soltuion won't resolve the issue but it help more the rate me fixya.
Jun 04, 2008 | Gigabyte GA-8LD533 Motherboard
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Gigabyte motherboard cd
You do not not need your motherboard CD to preform a format on your drive. Any windows CD. Win XP home, XP Pro, Win 2000 will format your hard drive. You can also use the hard drive's Mfg's utility disks & creat a bootable floppy disk or creat a bootable CDROM disk that will not only allow you to format the hard drive but also fun testing on the drive. You can even pick your cluster size & FAT file. Write down the name of your drive & model no#. Go to the Mfg's web site & download the utility software. Chances are Windows will have most of your boards drivers in it's data base. All you'll need to do is download from Gigabyte your missing drivers. You'll need you complete model no# & version no# if you can find it.
Mar 12, 2008 | Intel Motherboard
Windows xp instalation
use bootable original XP CD ROM ,
First : Insert CD in to drive
2-Go to BIOS change the bootable priority as boot from CD
3-Enter serial number when asked
4-give necessary answer
After 20 minitus it complete.
Nov 26, 2007 | Microsoft Windows XP Professional With...
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
How to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
Sep 28, 2007 | Microsoft Windows XP Professional With...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
