Question about Bosch 24 in. SHU43 Built-in Dishwasher
Does not wash
Water seems to fill; sounds like motor is trying to work, clicks off, then seems to try again. i know that the drainage impeller is not relevant, but it is clear and drain pump seems to work....i can not find other blockage but maybe looking wrong place. also took out control board and looked for burns under relay...didnt see burns but resoldered critical points anyway
  • lensteinbach Jan 03, 2008
    many thanks for your help; the issue was solved and i believe i posted the solution. Theimpeller could not be turned by hand; however i learned that you could use an 8mm socket on a ratchet to turn it from its hub (from the inside of the washer bottom of tub at impeller; i was able to turn it but not loosen it enough. a tech then suggested filling the basin with roiling boiling water ---that either the loosening of stuff or expansion/contraction might do the trick. Indeed that work. If there is a next time i will try the boiling water and 8mm socket first
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Wash pump motor is either jammed or not working. it its not jammed check the capacitor first..most common faults for your description
Posted on Jan 03, 2008
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Dishwasher is not washing the dishes. Motor sound like it comes on, Water is drained aout and put in but it appears no rinsing or washing goes on. Don"t hear the arms rotating either. It goes thru the...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1776 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, you said you hear a quiet sound of a motor starting once the unit has completed filling with water right ? Be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues. (try placing both spray arms at 12 o'clock position and placing a cup upright in the top rack. If the arms move and the cup fills, you've got circulation...if neither, you don't)
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump or severed somewhere between the motor and control, maybe where the door pivots during opening...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Apr 19, 2011 | Asko D1776 Built-in Dishwasher
The spray arms on my Asko 1716 dishwasher do not turn - water enters the unit and drains easily, and the heating element also seems to work. The filters and sump are clear, as are the air gap and the holes...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, as you mentioned. What you may not know, is the impeller itself is not serviceable, the entire motor/pump must be replaced unfortunately.
Before declaring it is indeed a motor/impeller issue, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump obviously it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
Regards,
Macmarkus :)
Mar 09, 2011 | Asko 1375 Dishwasher
It sounds like a small rock, dime, or screw may be loose inside the macerator and is rattling around. Can i extract it?
Sounds like you have a broke impeller or the bearings in the motor are bad. Clean it out real good and wash off the impeller and fill with fresh water and try it again allot of times the float will get stuck and the pump will over heat destroying the sealed bearings in the shaft between the pump and impeller this pump uses water to cool the bearings so if it has been dry running you will need to replace the pump.
Dec 08, 2010 | Saniflo & Saniplus& Macerator Pump
On my model 1475, the washer arm doesn't seem to be working and the wash cycle isn't working. It still fills, drains, and goes to the heat cycle. . .but we don't think it is doing the actual washing. ...
Hello, Welcome to FixYa. Based on your description and provided the dishwasher is indeed 1) an Asko 1475 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately. First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? ( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues ) If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design. What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor. Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro. I'll watch for your reply. Regards, Macmarkus :)
Nov 26, 2010 | Asko 1375 Dishwasher
MY DISHWASHER WONT KICK INTO WASH CYCLE CAN HEAR THAT IT WANTS TO BUT DOESN'T ..IT WILL FILL AND DRAIN AND DRY...CHECKED DRAIN AND FILTER CLEAR
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump.
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Viking...built by "Asko"...are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
What happens typically is the ball-bearings from the upper rack holders ( which are plastic which fatigues due to heat and fall apart ) fall out making their way into the sump, hence breaking the wash impeller from the motor.
Good luck,
Macmarkus :)
Aug 26, 2010 | Viking 24 in. Professional Series VUD141...
It seems like there is not enough pressure to activate the cleaners they barley move,i have watched it while it was open its trying to work
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump.
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
This unfortunately is common with Asko dishwasher and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders fall out making their way into the sump, hence breaking the wash impeller from the motor.
Good luck,
Macmarkus :)
Aug 24, 2010 | Asko D1776 Built-in Dishwasher
Drum not turning despite belt ok and motor ok, lots of sediment from drainage pipe
check the pump/impeller for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Washing Machines
Bosch 24 in. SHU43 Built-in Dishwasher Logo
132 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
