Nokia 7310 Cellular Phone Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Contact service my 7310 displays this message (contact service) & shut downs.
Anonymous
Level 2:
  • Expert 160 Answers
  • Posted on Sep 27, 2009
Anonymous
Expert
Level 2:
Answers
160
Questions
0
Helped
129265
Points
625
Plz flashing your phone
Security code nokia 7310
follow that instruction and fix it.
God bless you
Instructions
    • 1
      Contact your service provider or Nokia and ask them for a code to unlock your phone. They should give you this code for free. Make sure you write the code down so you will remember it in the future.
    • 2
      Find software online to download that will unlock your phone. Most Web sites offer this type of software for free. Try searching for this type of software on search engine sites like Google or Yahoo.
    • Sponsored Links
    • 3
      Locate the serial number (or the IMEI number) of your phone. Check underneath the phone's battery for this.
    • 4
      Download the software and begin entering in the manufacturer (Nokia), the serial number, and the phone's model number. A list of codes will be displayed. Write down these codes.
    • 5
      Remove your SIM card and turn on your phone. Then, enter the code into your phone, including the number signs. Do this after the "Insert SIM Card" display appears.
Read more: http://www.ehow.com/how_2032655_unlock-nokia-phone.html#ixzz2ZKL0YxNY
Nokia 7310 Cellular Phone Diplaying Contact Servise Why? Please help me to solve this problem
Hello, welcome to Fixya!
the phone has reached end of its life span, that's why it is asking you to "contact service". Contact service actually means, contact the manufacturer (Nokia). The phone's operating system is affected and cannot boot.
I think its high time you purchased another phone.
Good luck.
2helpful
Hp printer model M1522nf displaying permanent storage init. with both green ready & orange exclamation lights flashing & unit will not function
HI,
This a formatter failure, sounds like the formatter went out while trying to do a hard reset or after updating the firmware,
Try doing a nvram:
Turn the printer off and hold the down arrow and the cancel button
Turn the printer on while holding the two buttons down
Continue holding until you see the permanent storage message and wait for the ready message to display
If this doesn't work call hp and tell them that printer is frozen and will not initialize, this is due to a formatter failure. If it has been less than 2 years since the purchase date then you will apply for a service note and will be able to have the printer serviced for free, Contact hp's tech support at 1800-334-5144.
Al
I have a HP Office jet 7310 all-in-one. Printing stopped and an error message that says remove and check cartridge on right. I did, but the error message won't go away. What can I do?
Cold reboot. Disconnect all wires and cables after shutting down as much as possible, leave disconnected from power and computer for 3 minutes then follow OEM instructions for hook-up and restart
I get a message the catridge inserted is not intended to use with this printer
HP has embeded tools to detect if you are using the original HP cartridge or not in their printer driver.It detect fake catridge & display message to the user.That is the message you are encountering.Avoid using fake catridge for long printer life and good quality printing.
1helpful
Error message "remove and check cartridge on right" Did that and shook up the cartridge still feels like it has ink but when I replace it the message does not go away. If it is truly out of ink why doesn't...
Step 1 - Remove and reseat the cartridge
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridgec00143341.gif
  3. Pull the problem cartridge out of the print carriage.
  4. Inspect the cartridge. If the cartridge is new, make sure to remove the protective tape covering the nozzles.
  5. Reinsert the cartridge into the carriage at a slight angle, as shown in the illustration below. When the cartridge is fully inserted into the carriage, rock it upright. Figure 2: Reseating the cartridgec00143342.gif
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration below. Figure 3: Closing the cartridge latchc00143343.gif
  8. Close the cartridge access door.
  9. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Step 2 - Clean the contacts
NOTE: Try to clean the contacts quickly enough that the cartridges are not outside of the unit for more than 30 minutes. The ink can dry and clog the nozzles if the cartridges are outside of the unit for too long.
  1. Gather the following items to clean the cartridges and print carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
  2. Remove the problem cartridge.
  3. Place the cartridge on a piece of paper with the nozzle plate facing up.
  4. Unplug the unit power cord.
  5. Lightly moisten the lint-free cleaning material with clean water.
  6. Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty. Figure 4: Cleaning contacts (avoid nozzles)c00143349.gif
  7. Clean the carriage contacts. Use new cleaning material if the material used on the cartridge contacts is no longer clean.
  8. Let the parts dry for five minutes before reinserting the cartridges. Figure 5: Cleaning carriage contacts c00143350.gif
Step 3 - Remove cartridges and shut down the printer If the steps above have not helped and the error message is "Remove and check the right cartridge ," the following steps may help:
  1. Remove both cartridges, lower the latches, and close the printer access door.
  2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
  3. Turn the printer back on by pressing the On button.
  4. When the message display reads Insert right cartridge , open the access door and replace the cartridges.
Step 4 - Download a firmware updateIf the error is still displayed, follow the steps below to see if downloading a firmware update from HP might help:
  1. With the power on, open the printer and remove the cartridges.
  2. Relatch the empty carriages and close the printer.
  3. Open the printer and reinsert and relatch the cartridges.
  4. Close the printer and look at the LCD display.
    • If the LCD now shows no error, the original error was caused by a problem that is fixed by HP's firmware update. Though the error has cleared, it may come back in the future, or other problems such as slow printing may occur. To fix these problems, download the latest firmware update from HP. Click here to see how. Make sure to download the firmware update, rather than a driver or other software.
    • If the error message is still displayed on the LCD, the firmware update probably will not fix the problem. The update does fix other problems however, and it should be installed when it is convenient.
Step 5 - Replace the cartridge or service the printerIf the steps above have not helped, replace the cartridges or service the printer. Replacing the cartridges can help determine whether a problem is caused by the cartridges or the unit. However, cartridge replacement will not solve problems that are caused by the unit.
  • If you have not previously tried replacing the cartridges to solve the problem, or if replacing the cartridges solved a similar problem in the past, replace the cartridges now.
  • If you have already tried cartridge replacement without fixing the problem, the unit may need to be serviced. Contact HP to see how to proceed. Click the link at the top of this page for contact information.
1helpful
Carriage Jam
If you can get the covers off. push down on piece that is blocking the cartridges. Otherwise, it is uneconomical to repair.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
