Question about Air Tools & Compressors
Reset button trips about 2 seconds after i turn it on. bought from harbor frieght
    President:
  • 1,167 Answers
Burnt out motor or the motor is working to hard is the pump easy to spin by hand also how many amps does it pull when the motor starts get back to me or it may just be a weak overload switch
Posted on Sep 27, 2009
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
How do you remove the crankshaft pulley? I have not been able to figure out a way to keep it from rotating so that I can break the bolt loose.
Your best and most likely best thing to do is go to your local auto parts or hardware store and depending on your location if you have a Harbor Frieght store near you is to get and electric impact/ at harbor frieght you can get one for about 50 dollars. Don't forget to get the correct size 1/2 drive socket. You will need something like that as well to make sure it's put on there good when you put it back together anyway. There are other ways but this is the quickest and best way to go on and get the job done. Gave you a picture of one below for the one from Garbor Frieght that goes for 50. I hope this helps and good luck.
Aug 06, 2011 | 1994 Nissan Sentra 4-Door
Fuel air mixture is to high resulting in exess exhaust emisions
hook a vacuum gauge up on the side of your carbs are a screw not same color as you carbs if you have 2 carbs you need 2 gauges bring your vacuum up to the highest vacuum match carbs go to harbor frieght for your gauges
Mar 03, 2011 | 2000 kawasaki VN 1500 Vulcan Drifter
I had my oil changed in October after the "oil
Try this procedure and let me know if this does not work;
Turn the ignition switch to the "On" position but do not start the engine.
1. Press the Trip/Reset button until "Setup Menu Hold Reset" is displayed.
2. Then press and hold down the Trip/Reset button for approximately 2 seconds until "Reset For System Check" is displayed then release the Trip/Reset button.
3. Then immediately press and hold down the Trip/Reset button again for approximately 2 more seconds until "OIL 100% RESET IF NEW" is displayed then release the Trip/Reset button.
4. Then immediately press the Trip/Reset button once to display "HOLD RESET IF NEW OIL" then release the Trip/Reset button.
5. Then immediately press and hold the Trip/Reset button again for approximately 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Turn off the ignition switch, and then start the engine to verify that the reset procedure did work, and you might have to repeat the procedure if the Trip/Reset button is not pushed fast enough, or it is not held down long enough, or it is held down too long during the reset procedure, and it may take a few attempts to be successful.
Nov 11, 2010 | 2006 Ford Explorer
Yellow oil symbol kept turning on
this could be due to low oil. you need to check your oil level. if it is full i would do an oil change with a bmw filter. there is a difference in filters. the service engine soon light will have to be diagnosed. meaning pull codes to point you in the right direction. great car though. happy holidays
Dec 24, 2009 | 2000 BMW 3 Series
How can I get rid of the messages on my board....(ie. regular maintenance due)
1. Press and hold trip odometer reset button 2. Turn ignition key to run position KPII (not the start position)
3. Wait 30 seconds or until service light "!" begins blinking
4. Release Trip Odometer button
5. Turn ignition to off position
If that doesn't work try:
2. Turn ignition key to run position (not the start position)
4. Turn ignition to off position, the service light continues blinking
5. Release Trip Odometer button
should reset it for you
Jul 03, 2009 | 2003 Volvo S60
How do you reset c230 2007 mercedes benz resetting the maintenance service indicator?
Try this, it is the procedure for resetting the ASSIST computer on many Mercs
1...Turn Key to position No:2 in the ignition / steering lock and immediately press AND Hold the button "000.0" (the trip reset button) TWICE within the space of 1 (one) second.
2…Turn the key to position No: 0 in the ignition / steering lock. Then release the button.
3...Press AND Hold the button "000.0" (the trip reset button) and turn Key to position No:2 in the ignition / steering lock. Keep button pressed
After about 10 seconds
the service indicator will reset and an acoustic signal may briefly sound
That should do it....Good Luck…...Let me know if it works?
Jun 28, 2009 | Mercedes-Benz C230 Cars & Trucks
How do i reset my kilometer gauge after changing oil or does it reset to 0 automaticly
Resetting Oil Service Light on your 2002 - 2006 MINI Cooper and Cooper S, and 2007 - 2008 MINI Convertibles:
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
5. Watch for the word “RST” to appear on the Odometer indicator.
7. Wait for the “RST” message to fl ash.
Apr 12, 2009 | 2003 Mini Cooper
I changed oil and oil filter myself , but how I could turn off regular maintanace light from the dashboard?
hi ,
1.) turn ignition switch to position I.
2.) press and HOLD the reset button for the trip odometer .
3.) turn the ignition switch to position II ( within 2 seconds )
4.) HOLD the reset button for the trip meter until the original value has been reset
5.) release the reset button for the trip odometer within 4 seconds .
6.) the instrument cluster will give an audible signal when resetting is completed .
7.) if procedure didn't reset , repeat procedure carefully .
J5
Jan 18, 2009 | 2006 Volvo S40
Mini dash
4. Wait 3 seconds
5. Push trip button
8. Push trip button
Or this:
backbutton0001.gif Article Date: Jan 02, 2007
Car Accociations: NEW_MINI
Hits: 16731
Jan 13, 2009 | 2002 Mini Cooper
Air Tools & Compressors Logo
89 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
