Question about Battery Technology Office Equipment & Supplies
Lc61 black ink not printing
Just bought a brand new brother lc61, but black ink is not printing. I've tried cleaning it and everything, but it just won't print. all color cartridges are working fine.
    Sergeant:
  • 191 Answers
Please just your have refling black cartriaged ? If yes
then again refling cartries black and add printer.
and you go printer page and select to B&W and ok select and
aply print.
other no result in black print then you parchase a new black only
cartries and use.
Posted on Sep 27, 2009
Why won't my Brother LC61 printer pring the color on test pages?
You may find more success with water than alcohol - most inks are water based these days. However, you may find that ink has dried in the head, which you won't resolve. I can't remember if these have changeable heads or not.
Final option is to try printing a whole full page of cyan colour. It might eventually get through the dried ink and soften and start printing.
Jul 31, 2014 | For Dummies Brother LC61 Combo Inkjet...
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Black ink 0n LC61 PRINTER HEAD
most likely the printhead needs replacing, it is possible that it might be covered under warranty, call brother and check.
also make sure you have black ink in the cartridge and if you did only 1 cleaning, you may need to do 3 or 4 to see if its better, ink has to flow through the tubes.
Apr 06, 2014 | Brother MFC 420CN All-In-One InkJet...
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
My Lc61 will not print black--on the test page, the colors are fine. I've replaced the ink cartridge and it says it's full but won't print
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
May 26, 2011 | Brother Office Equipment & Supplies
Brother lc61 printer will not print in black even wit a new cartridge installed
Hi innercepter,
1) Open the printer
Oct 15, 2010 | Brother Office Equipment & Supplies
I replaced the black ink cartridge, Innobella, LC61Bk, all correct, for the first time in my MFC-990CW Brother fax, etc.times 3!!!! And I get "white" lines through the text. Yes, I have gone throught the...
i HAVE A lc61 SERIES BROTHER INNOBELLA AND I AM NOT ABLE TO PRINT. wHEN I TEST THE PRINTING I GET ALL COLORS BUT BLACK ON THE TRIAL DEMO I TRIED CLEANING BUT IT STILL DOES NOT WORK WHAT CAN I DO???
Oct 16, 2009 | Brother MFC-990CW COLOR INK-JET MFC Ink...
1,663 people viewed this question
Top Battery Technology Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Battery Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
