Question about Hobie Boating
Deep scrape hi, my hobie has been scraping against a up right on my trailer. It has been shaving the plastic and bunching the plastic on the upside how do i fix this Regards, Rod
    Problem Solver:
  • 10 Answers
Pad the trailer upright and don't worry about the damage to the kayak if it hasn't worn a hole.
Posted on Nov 14, 2009
After using the a40 only a few times, the pedal crank assembly shifted to the left so that the crank arm on the left side scrapes against the plastic casing.
I am getting same issue? Are you able to resolve your problem.
This is really bad. Schwinn is supposed to be good company.
Jan 01, 2014 | Schwinn A40 Elliptical Trainer
Oven cleaning
I prefer non chemical products if possible. If oven wall is smooth ans grease is baked on hard, you might start with a shaving razor, the bendable kind, keep it low to the surface to not scratch. Careful- it's easy to cut yourelf! Get what you can this waay. Don't use dull razor - coulf damage oven Wet a rag with vinegar and set against surface, maybe half hour to soften. Try to scrape off with plastic spatula? Or cut plastic bottle to use an edge to scrape. More vinegar - until it penetrates. scrape, wipe, etc. Vinegar will do it, takes time, though.
May 03, 2013 | Home
What are the benefits of electric shavers?
The benefits of shaving with an electric shaver are the considerable ease of use and the reduced chance of getting cut or scraped during a shaving session.
Feb 06, 2013 | Health & Beauty
Dryer drum makes a scraping metal sound
bushings at edges front and back are bad front ones are long and flat rear one is a small short plastic sleeve over center shaft. requires ordering parts from manufacturer and almost total disassembly
Dec 29, 2012 | Dryers
My abs light is on and when I turn slightley to the right it sounds like my tire is scraping against metal what could that be.
Sounds like a Brake Pad or Brake Pads is worn out and metal is starting to scrape metal instead of Brake Pad. A Caliper sticking will wear one Brake Pad sooner than the other one. Check for grooves forming on the Brake Rotors.
Feb 26, 2011 | 2003 Ford Expedition
The head of the mixer seems to dip to deep into the bowl. It is scraping the bottom and chipping the attachment.
Hi, Put your mixers head in upright position and adjust the screw between the head and the stand. This will rise the head (one rotation is about 1 mm) and the attachement will not scrape the bowl.
Jun 30, 2010 | KitchenAid KSM150PS Artisan Series Stand...
What could cause metal shavings in oilpan 2003 altima 2.5?
metal on metal contact is causing peices of your rings or cycinders to be scraped away. these pieces circulate and because they are heavier than oil they sink to the oil pan as shavings
Jun 20, 2010 | 2003 Nissan Altima
Dryer is heating but drum making very loud noise like scraping against something
next time send model number,check the glides on the front bulkhead that the drum rides on,also check the pulley and rollers while your in there and check the blower wheel,make sure it isn't cracked or loose scraping against the housing
Jan 31, 2010 | Amana Dryers
Scraped arock and damaged some sort of fuel module
is it a black plastic square shaped box. if so it is call the evap canister.
Jan 06, 2010 | 2007 GMC Sierra 3500HD
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Boating Logo
144 people viewed this question
Top Hobie Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Hobie Boating Expert? Answer questions, earn points and help others
