Question about GE Refrigerators
My rm7401 L will not work on 12v . works on gas and 240 . Led light does not come on and will not cool. When I switch it over I can hear the contacts open or close but no light comes on.
The 12v is only supposed to work when your engine alternator is running as this as you have stated is a big drain in the 12v system. It will only normally switch on when your ignition light has gone out and the engine alternator is charging.
Posted on Jan 20, 2014
5 Suggested Answers
  • 61 Answers
SOURCE: Whirlpool Gs5shaxnb02 Ice maker
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Posted on Oct 06, 2008
SOURCE: Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Posted on Apr 12, 2010
  • 327 Answers
SOURCE: no cooling on 12v or gas
Hello,Depending on the age of the unit, it could have a compressor going bad on it, as the compressor gets hot the valves may not be seating correctly or may be burning out.
You may have also lost some refrigerant, but I am going to lean more to a bad compressor.
Thanks
Posted on May 30, 2010
  • 3 Answers
SOURCE: electrolux 3 way fridge
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Posted on Nov 13, 2010
Dometic 3 way fridge won, t work on 12v
read the manual .is all I can suggest
Feb 14, 2015 | Dometic Refrigerators
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Jul 07, 2010 | Electrolux Refrigerators
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
LP 240 stopped working. No lights, no fans, nothing.
Please describe the status of the LED indicator. No LED would indicate a failure of the power supply. I can help you with that.
Flashing red would indicate a fan/lamp problem. Some lamps fail prematurely before the lamp hours are up.
If it is the power supply, no lights at all, I can get you running again. These units have fragile power supplies that can burn out with the slightest power surge. A UPS goes a long way to save future headaches.
Jan 16, 2009 | InFocus LP 240 Multimedia Projector
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
