Question about Apple iPhone Smartphone
IPhone not making or receiving calls after bluetooth use
Since I upgraded my iPhone 3gS firmware to 3.1 everytime I have paired the phone to any blue tooth device and disconected afterwards I'm not able to make or receive calls nor sms's until I reboot the device.
Pair visor go bluetooth with iPhone 3GS
iPhone 3 GS, This should be able to help you: http://www.lcd-screen-digitizer.com/iphone/iphone-3gs-usb-port-flex-+mic+ringer-speaker+antenna-us.html
Sep 27, 2012 | Supertooth One Bluetooth Visor...
Iphone 3GS not pairing to plantronics voyager 520
Without turning the headset on, turn the bluetooth on for the phone. Select the headset that is paired, and select Unpair. Then turn bluetooth off. Put the headset into the "discover" mode, by holding down the power button until the light flashes red and blue. Then turn the bluetooth on for the phone, and it should "discover" it. It should ask for the passcode, normally 0000. Once you enter that, it should pair. After that, you should be alright. You can turn the headset off and back on again and it should connect right away.
Hope this helps.
otherwise try this : http://www.plantronics.com/media/media_resources/easytopair/
Jan 12, 2011 | Apple iPhone 3GS Black (16 GB)
Can not connect bluetooth to MY65T Navman
I've got MY65T working on an iPhone 3GS. I previously had the problem where it would pair and retrieve phone book, but not transmit or receive voice from my iPhone when making a call.
The last thing I did that fixed it was to remove the bluetooth pairings and "reinstall software on your navman". I don't know if this may remove some of your settings / POI / etc. This was a new purchase so I didn't have anything to lose.
Before doing this I had upgraded the navdesk software to 7.30, and installed the latest firmware for MY65T. Firmware is located at http://www.navmansupport.com.au/Software/My%20Series/MY65T/MY250___352.htm
Details:
-remove the phone bluetooth pairing from the Navman from Settings / Bluetooth / My Paired Devices / [your phone] / delete
-remove the bluetooth pairing from your phone's settings
-connect navman to PC and launch navdesk
-click "My Navman" / "Reinstall software on your Navman"
-download the install file if prompted
-accept the reinstallation prompts and complete reinstallation
-set your phone to discoverable over bluetooth (just keep it on the Bluetooth settings screen on iPhone)
-go to Settings / Bluetooth /" Search new devices" on your Navman
-click your phone's name on the navman's discovered devices
-enter the PIN onto your phone when prompted and accept the pairing. This takes a little while.
-test handsfree!
Nov 29, 2010 | Apple iPhone 3G
My 3GS iphone bluetooth headsets disconnect from the phone periodically and never use to. Solution? I even purchased a new headset, same problem.
Bluetooth on iPhone:
On iPhone:
1) Go to Settings
2) Go to Reset
3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
On Headset:
Clear all previous pairings.
Once iPhone reboots, turn on Bluetooth.
Nov 24, 2010 | Apple iPhone Smartphone
I just got a new iphone 3gs, having bluetooth
Hi, I have an iPhone also, you don't connect to other phones anymore, like if you did with normal mobile, if say you searched in a full room of people with the iPhone you would just find the printer in the corner!?!?, bizarre i know, but thats Apple for you, (2 steps forward, 5 backwards) you just connect to Bluetooth appliances like, your car, printer, pc/mac.. Thanks Mark
May 04, 2010 | Apple iPhone 3G
How do I pair my iPhone 3gs to my 2008 Lexus SUV?
Hi, to pair bluetooth you need to do following:
1. turn off tooth
2. turn off bluetooth function on the iphone
3. push on and hold it on the bluetooth until solid blue light comes up
4. turn on bluetooth on the iphone, it finds it in 2 sec, password 0000
iPhone is not perfect, but it's one of the BEST phone ever made. Have it for 2 years and enjoy every second of it
Take care
Apr 22, 2010 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
Iphone won't work with bluetooth in mazda 3 2010 My iphone shuts off whenI try to use the bluetooth system in my mazda 3
iPhone has had bluetooth since the first model in 2007. With iPhone OS/firmware 3.0 (free for all iPhone users), iPhones are fully A2DP compliant and link with Mazda bluetooth.
My current experience is with a 2010 Mazda3 and iPhone 3GS, where I get phone and iPod functionality via bluetooth (yes, without jailbreaking), though the steering-wheel controls are limited to play/pause and volume only.
Jun 12, 2009 | Apple iPhone 3G
I want to use my iphone 3g bluetooth in every situation
You can't send and receive files with the iPhone's bluetooth. Version 3 of their firmware will supposedly provide this functionality, but only on the iPhone 3G. (2G models don't have the necessary hardware)
As for the hands-free car setup, that should work just fine. It's a matter of pairing the two devices together.
Apr 20, 2009 | Apple iPhone 3G
Apple iPhone Smartphone Logo
44 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
