Question about SkyScan 86742 Digital Atomic Wall Clock
I have a87900 model skyscan,can;t get it reset after replacing batteries
Skyscan atomic clock
  • 2 more comments
  • Albert Parlee Mar 01, 2009
    Unable to set the DAY everything sets ok.This is Skyscan Mod.86931
  • Anonymous Mar 18, 2009
    I changed the batteries and am waiting for outdoor temp to diplay before setting clock. I waited about 5 minutes and still no outdoor reading.
  • Anonymous Mar 12, 2014
    how to set time on clock skyscan
  • Anonymous Mar 20, 2014
    I live in Arizona don't want my clock to change to day light saving what do I do?
they have instructions online
Posted on Sep 04, 2008
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
Posted on Aug 07, 2008
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
Get into this link. You can see the user manual for your Skysacn atomeic clock here. You can adjust your clock according to it manual. OK.
Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
I cannot get my SkyScan Atomic Clock to sync with Colorado.I have replaced the batteries and I have waited since Nov 6th and it stil hasn't happened. My Clock is model 87315. Please help
I have the same model. Make sure you have good batteries and move the clock away from any electrical equipment. Since WWVB broadcasts at a frequency of 60kHz, this could be a harmonic of 60 Hz.
If all else fails, remove the batteries, take the clock outside and reinstall the batteries. If you do this at night you should pick up a signal..
I just had to move my clock out of the computer room and it picked up the signal at noon.
Good luck
Nov 08, 2011 | SkyScan 86709 Atomic Wall Clock
Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at
Apr 04, 2010 | SkyScan 86709 Atomic Wall Clock
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
How do I adjust the time zone. I set the clock and in a few days it is 3 hours earlier Pacific Time and I am in N. It is a skyscan atomic clock CN6 V00U. Thank you, Kent
Take out the batteries, let stand for about 30 sec replace batteries and reset clock, when ask if you want to auto set daylight time "yes", and continue.
Oct 16, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Cannot reset my SkyScan Atomic clock after changing batteries
Online manual is at link
Dec 29, 2008 | SkyScan 86709 Atomic Wall Clock
Cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
SkyScan 86742 Digital Atomic Wall Clock Logo
1,058 people viewed this question
Top SkyScan Home Experts
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a SkyScan Home Expert? Answer questions, earn points and help others
