Question about Lexmark X1240 All-In-One InkJet Printer
Print problems I have the lexmark x1240 all in one printer. it will scan photo's to a file on my computer (which means there is communication) but when i try to print, it says there is no communication. what is wrong?
    Scholar:
  • 70 Answers
Please uninstall the printer drivers using cd or from add remove programmes from control panel.
and then unplug the printer and restart the computer without printer plugged in
Then install the printer using the printer driver cd and when prompted connect the printer to the computer.
this should work if still doesnt work please get back to me.
Regards
Mohammed.
Posted on Dec 17, 2007
My lexmark x1240 all-in-one will not print. It saves XPS files and when I go to open them it will not open them. I have already installed the XPS reader. Also, when I try to scan, a box pops up saying...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lgJCxt. Select your operating system, download and execute the file.
Try to scan again to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support for additional assistance.
Oct 11, 2011 | Lexmark X1240 All-In-One InkJet Printer
Hello
turn off the printer wait for 15 seconds and turn it on again....
this will solve the problem
Feb 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmak x1240 all in one will not communicate with computer
Hi, I am writing you regarding your problem with the printer.
If the printer is still not printing, try first replacing the usb cable, and try a different USB port.
If still no luck , then you will probably need to reinstall the driver software, either from CD , or downloading the file from Lexmark website.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Always start printer setup with printer unplugged, and chose printer as default during install.
Mar 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
HP Photosmart C5100 All-in-One series does not scan to my computer
. Click on "Start," and "Windows photo gallery."
2. Under "Windows photo gallery" click on "File" and " Import from camera and scanner."
3. Select the "Lexmark X1240 printer" and click on the import button.
4. To begin the scanning process, click "Scan Now.
Jul 31, 2008 | Office Equipment & Supplies
Can't find x1240's All-In-One Print Center
TENGO PROBLEMAS CON LA IMPRESORA LEXMARK X1240, NO FUNCIONA EL ESCANEO, Y LA FOTOCOPIA
Jul 14, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark printer x1240
go to the link select http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html your o/s then down load the drver and install ready to use your printer for scaning amd printing
May 16, 2008 | Lexmark X1240 All-In-One InkJet Printer
Scanner not workin-lexmark x1240
Which operating are you using if your using (Vista use windows photo gallery to scan)
Mar 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
