Question about HP DeskJet 920c InkJet Printer
Orange Fill Cartridge Light still Blinking after Cartridge change
Changed cartridges, and orange light is still flashing. Is there a reset switch that needs to be triggered?
  • n2narcosis1 Sep 27, 2009
    Pardon... But this fix-ya site seems to have more adds and marketing rubbish than easily accessible solutions. I have a slow internet connection, but accessing the solutions should not be so cumbersome.
  • 26 Answers
SOURCE: orange cartridge light error keeps on blinking!
it sound like a bad carriage assembly: part # C4713-60039
it lists for around $147.
Hope this helps
Posted on Mar 24, 2008
getbharti
  • 33 Answers
SOURCE: Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Posted on Nov 28, 2008
SOURCE: hp 1160 light blinking
orange & green light on
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: BLINKING ORANGE LIGHT AND NO PRINTING
I just experienced this with my 920c. I cleaned the contacts in the cartridge holders with alcohol and the problem went away.
Posted on Feb 03, 2009
rylee_smith
  • 8619 Answers
SOURCE: orange light blinking on check your cartridge keeps coming on
Hi!
It is a very common problem and it can be resolved easily. Please see the following HP links to resolve the issue you are facing with---
HP Photosmart
and
HP All-in-One
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 19, 2009
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    count how many times the lights flash, here is what they mean
    Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
    Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
    Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
    Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
    Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
    Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
    Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    My printer cannon ip1980 is now not reconized to colorink and blinking orange and i press the orange buttom but it is not get and i cannont print and still orange blinking . with regards , kan nyunt...
    1. if the printer monitor says that your colored cartridge has run out, you can press the orange button for at least 5-10 seconds and it will solve your problem. it is called a cartridge reset.
    2. if the printer says that it cannot recognize the color cartridge. practically, you need to change your colored cartridge with a new one. However, if you have changed the color cartridge and still the problem is the same, you might have a carriage problem. try to clean the contacts of the carriage and try reinstalling your cartridge again.
    I hope I've helped you with your problem.
    Jun 09, 2009 | Cannon Canon i960 Photo Printer
    The orange light flashes even though I have changed the colour cartridge, The printer will not print
    change the catr insecting unit and the cable together for it to work well. that the problem
    May 23, 2009 | HP DeskJet 940c InkJet Printer
    Jan 31, 2009 | HP DeskJet 920c InkJet Printer
    HP DeskJet 722c orange ink light flashing
    Try changing the color cartridge. Also it is a good idea to clean the electrical contacts if it looks dirty.Use slightly damp(use water only) q-tips .
    Hope this helps
    Mar 27, 2008 | HP DeskJet 722c InkJet Printer
    Orange cartridge light error keeps on blinking!
    clean the carriage home
    check the data cable for the carriage home
    check the media sensor on the left of the plotter media bar
    Mar 12, 2008 | HP DesignJet 450c InkJet Printer
    HP DeskJet 920c InkJet Printer Logo
    65 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
