Two month old samsung la40b650 only switches on after power on/off 3 or 4 times. After reading of similar problems with samsung maybe I should check the 4 capacitors bulging on the power board. hope to do that tomorrow.
  • 286 Answers
SOURCE: viewsonic n3251w - no power
A lot of TVs are having their power boards go bad due to a poor brand of capacitor (CapXon usually).
If small problems are noticed with the tv, the solution is to replace the capacitors. However, once the TV gets to the point where there is no power at all any more (not even a stand-by light) then the power supply has to be replaced.
Visit Viewsonic's website or call your local Viewsonic repair shop to get a price on this board. They are usually under $100.
Posted on Nov 26, 2008
  • 257 Answers
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Posted on Aug 13, 2009
  • 3 Answers
SOURCE: Magnavox 19MF337B/27 LCD TV problems
The bad capacitors in this set are usually NOT on the power supply--they are on the other (logic) board. You will find several bulging capacitors there. Replace em all....
Posted on Nov 17, 2009
  • 2318 Answers
SOURCE: Samsung 32'' LN32A330J1 not turning on
Check this website to find the part(s) you need.
Posted on Dec 29, 2009
Testimonial: "The link provided by the expert was excellent. I was able to find the product easily. Replaced the capacitor and thanks !!! the TV is working again"
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
What are the signs of a bad ignition module problem for a 1998 olds bravada
Some ignition modules were sensitive to strong radio, radar or electromagnetic interference but that type of module problem was more than a decade before your car was made but if the car stops in the same place every time I would be suspicious.
The symptom you describe is reminiscent of hall-effect triggers before they finally cease to work but again that technology is largely firmly in the past apart from a few exceptions.
I am wondering if your car even has a distributor or a separate ignition module.
Your description implies the engine cuts out like it was switched off but doesn't exactly say so. A second or two of reducing power before it cuts could indicate a faulty fuel pump or fuel pump relay. It is wise to be precise about such descriptions. If the engine check light doesn't come on while the engine is still rolling then it is unlikely there will be any fault codes to read and it does suggest a fuel supply fault.
There is not very much in the engine management that will stop an engine dead in its tracks but the crank and cam positional sensors can. A friend experienced car symptoms similar to yours for months before discovering it was the crank sensor.
Feb 25, 2015 | 1998 Oldsmobile Bravada
2004 Yukon XL 1500, with the car off the radio circuit draws alot of current and drains my new battery in 2-3 days. Also maybe seprate issue my oil presure gage does not reset to zero.
With the problem with the battery draining, Get the chargeing system check out, End tell them all so to check for a short, As for the problem with the oil gauge change the oil pressure sending unit,
Nov 26, 2012 | GMC Yukon Cars & Trucks
Samsung admire shuts off on its own reads 0% when its fully charged
try to buy original battery and original charger, then try again, if problem persist show some oficial repairer maybe it is a charging ic problem due to waterdamage.for further help post comments.
Jun 28, 2012 | Samsung Admire SCH
What if my front control panel reads OF and the alarm is going off I have everything closed and set properly frig is only 3 months old
Press and hold energy saver and power freeze at the same time for 3 seconds. That will fix the problem!
Jan 03, 2011 | Samsung RF4287HA
The model is Samsung LN-T4661F. It power cycles at least 3 times every time I turn it on. Once the screen comes on there are, most times, pink pixels randomly all over the screen. I have to turn it off...
good day .maybe theres a defect in the board causing the screen changes abnormally. maybe the screen module is defective. just consult that problem to samsung service center to fix your problem.
Jun 24, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Lights on dash all flash on then off - no pattern to this
Look @ ignition switch Electrical part suspect contacts in switch are bad. Have replaced several of them for this reason.
Jun 24, 2009 | 1999 Oldsmobile Bravada
Prima 32'' LCD HD tv power problem.
Sounds like the TV is having problems connecting with the power board. Contact Prima and let them know about your problem. Some parts have lifetime warranties and maybe this problem is covered. Changing out the power board is pretty simple usually 3 or 4 connections and 6-8 screws. Nothing to technical, just take a snapshot of the board connections before you remove the plugs and check your picture before you close up the TV. If this is warranty work service call is usually comped.
Apr 08, 2009 | Televison & Video
Dvd tray wont open or close
@PrimePub : Have the tray replaced by manufacturer or ask manufacturer to ship one to you.
@at_viper : If still under warranty (i think so if only 3 months old) just contact your vendor about it.
Jan 13, 2009 | Philips HTS3450 System
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
Electro Med Services...
