Question about Bosch WAS24460UC Front Load Washer
Spin out of control, walks, screams and pounds the floor
  • 909 Answers
Not easy to diagnose as lots of variables to consider, but looking at it logically, it seems that there is no speed control. 2 things responsible for this. 1)Your electronic board. 2) The sensor connected to the motor. Most of the time it is the sensor. Tilt the machine careful sideways until motor is in full view. At the back of the motor, there should be a module attached to the motor.Remove a little cover to allow access to a round magnet. this magnet very possibly has moved. Carefully position the magnet into place correctly then replace cover. Retry wash. Board is expensive so after that, let the technician diagnose and rectify.
Posted on Sep 27, 2009
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Vibrates when it spins
Here are a few quick facts on washing machine vibration.
  1. All washing machines and dryer vibrate. Dryers usually have less vibration than washers because the load is only wet clothes (as opposed to a drum of water and clothes). Front loading washing machines cause high frequency vertical oscillation while top loading washers usually have horizontal oscillation.
  2. Almost all front loading washing machines are not recommended for use on standard joist-construction floors (most common floor type, compared to a concrete slab sub-floor). Manufactures like GE, LG, Maytag, Samsung, Whirlpool, Kenmore, Bosch and more, all recommend installing a pad like Silent Feet under the washing machine to absorb the vibration.
  3. The only alternative to using Silent Feet pads to prevent structural damage is costly upgrading of the sub-floor. This usually involves adding a second layer of plywood sub-floor and adding sister boards to the rafters that support the floor. But even this won't reduce the amount of vibration noise that you hear. Sub-floor upgrades can cost thousands of dollars.
  4. Vibration can also cause appliance "walking" (unwanted movement) usually during the spin cycle. Simply installing a pad designed to prevent walking can solve this problem and mean that you'll never have to reposition your washer after every load again. Both Original Silent Feet and Anti-Walk Silent Feet prevent walking, however for washers that move a lot or stacked units it is recommended that you install Anti-Walk Silent Feet for the best results.
You were not specific in either type or model. I hope the above information helps. Also, the size of the loads plays a great part in how a machine functions. have a nice day
You wer
Dec 16, 2013 | Kenmore Washing Machines
The machine is level but the drum spins as if it were not. loud and the machine moves forward
These new front load machines are much heavier and spin much faster than the top load machines. If you have old wood floors in your home or you live in a mobile home, the machine may tend to "walk" or vibrate on the floor. You can try putting something under the machine to help prevent it from walking as it is spinning.
Feb 23, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Tub gets easily out of balance when washing towels or jeans.It pounds enough it walks across the floor
there are three or four balancing springs under the drum attached to the frame and drum carriage chances are that one of these springs has broken or come undone they only realy do alot during the spin cycle if you are ambitious turn off the water and unplug the washer pull the back off and have a look see underneath if you do find a broken spring with a pair of pliers bend a new loop in the spring and hook it back up Good Luck
Oct 13, 2009 | Washing Machines
A new washer walks all over the floor on spin, we
This is a wild shot but you may still have some shipping blocks inside or especially under the machine.If its new I would call customer support.
Oct 03, 2009 | Frigidaire ATF6000ES Front Load Washer
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Bosch WAS24460UC Front Load Washer Logo
95 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
