Question about Cannon Lake Troll Manual Downrigger
My new cannon lake troll line counter doesn't seem to work? What is up, am i doing something wrong. This counter is on the boom and not as simple as the easi-troll...HELP
  • 76 Answers
Hi!
Make sure the cable is actually running in the pulley. The pulley is geared to the counter, so if the cable isn't turning the pulley, the counter won't be working.
It is quite possible to add a simple counter like the Unitrol series. (key #'s 12 & 13)
Here's a schematic for both:
Cannon Laketrol
Cannon Unitrol
Hope this helps!
Mike
Posted on Sep 27, 2009
Minnekota power drive 55bl. stuck at high speed. The foot pedal could turn the motor on and off, left and right, but when use slider to control speed it doesn't seem to have any contact.
If you can get inside the rheostat and move the wiper arm to properly wipe across the resistance then................
But often there is no getting inside and the only thing you can do is to replace the rheostat itself.
Aug 31, 2015 | Boating
Cable jumps off of roller at end of boom
I've had the same problem with my electric Walker down-riggers, the line guides didnt work well because of the crimp for the cannon ball return pully snags on the guide, the best I came up with is a cannonball snubber similar to ones used with Dipsey-Divers, made heavier for cannonballs, hope this helps
Jun 04, 2012 | Electric Cannon Mag 10 Hs Downrigger
Refrigerator doesn't seem to be getting cold. It was making a noise and now it doesn't seem like the fan or something is not working. everything in the soft freeze draw is thawed
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 15, 2011 | Kitchen Ranges
New MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
May 23, 2009 | MotorGuide Electrical Supplies
I have inheirited a Poulan counter vibe 3400 it
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem poulan then poulan then saw then look at list of models you will find 3400. Have worked on one or two of the 3400 and they seem to be a fairly good saw for home use.
Apr 07, 2009 | Poulan Garden
Ran aground on lake,now stuck on high speed,can't lower speed
My Minn Kota 55 powerdrive had the same problem except mine occurred while it was trailered in the yard. High speed only, everything else worked great. From what I could research the control module is a frequent problem. Took a chance and purchased a new control module and this cured the problem. Maybe this happening and running aground was just concidental.
Apr 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minn Kota Maxxum Trolling Motor
I had the same problems with my 70lb, my motor just quit while on the lake, took it to a minn kota service repair shop. I had two issues. One was the little magnet under the button on the foot pedal got recessed to far down, the tech told me if it happened again pop the button off and pull the magnet up some. Simple fix. I took it home put it back on the boat and nothing just a slight ticking noise heard from the pedal with no prop movement. So I thought maybe somethin was wrong with one of my batteries. Unhooked everything, tested both of them, all good. Even though there was hardly any corrosion, I clean everything, hooked it up and "WALLA"! Power! Problem solved, for now. Waitng to test again out on the lake
Aug 24, 2008 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Cannon Lake Troll Manual Downrigger Logo
756 people viewed this question
Top Cannon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Cannon Boating Expert? Answer questions, earn points and help others
