I can NOT get my pfaff model #1536 sewing machine to stay threaded. i have had it for about two years...and have never had a problem with it. above the needle there are two places were you are supposed to thread the needle through....one moves up and down (and it's silver)...and the other one doesn't move. the one on the left that doesn't move...i noticed is wiggly...would that have anyting to do...with the reason i cannot get my machine to STAY threaded????
SOURCE: threading a pfaff 9020 sewing
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
SOURCE: pfaff hobby 301 manual how to thread my sewing
Here is a manual you can download - http://gotoes.org/sales/PfaffSewingMachineManuals/ViewInfo.pl?Pfaff=1&Sewing_Machine_Model=HOBBY-301-420-INSTRUCTIONS
SOURCE: My Pfaff sewing machine has started to loop the
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
