Question about G7 Productivity Systems Versacheck Gold 2008 Full Version for PC
Failed to initialize Application. Unable to acquire context. Obje
When i start the Versacheck 2010 i have this mesage: Failed to initialize Application. Unable to acquire context. Object already exists. Somebody could help please???
  • dj21369 Sep 27, 2009
    Yes i did and i have same mesage
  • Peter Dragonetti May 11, 2010
    Hi there Have you try to reinstall the software Have a nice day
  • 729 Answers
Hi again
You have to first to check your firewall and your antivirus is not blocating the software to open. You can do that normally in the main screen of you antivirus, there you check if any files are in quaranteene and see if your firewall block for the program :O)
IF they are not blocating, the try to go here for support on the product homepage and write the same as here :
http://support.g7ps.com/support_central/ContactUs.aspx
Normally they can solve this, if not try to come back here :O)
Have a nice day
Hope that helps
Please rate my answer
Posted on Sep 29, 2009
How to crack versacheck gold 2010
Fixya will not give out any serial numbers, Activation Codes,
or Key Codes. It is illegal to pirate software
Oct 08, 2012 | G7 Productivity Systems VersaCheck Gold...
Looking for full versacheck presto pre 2010
You can download VersaCheck Presto v 9.8.19 which is compatible with Windows 7 from CNet here:
http://download.cnet.com/VersaCheck-Presto/3000-2047_4-10785072.html
Unfortunately, due to federal regulations, all previous versions of VersaCheck are no longer supported or provided by VersaCheck. The nice thing is that if you decide to purchase a new version, all of the data from your previous version are easily accessible.
Aug 10, 2012 | G7 Productivity Systems VersaCheck 2007...
I am unable to install the update for Versacheck 2002 - message is "Can't create output file: C:\Program Files\G7PS\VersaCheck 2002\_Update\ZUpdate.exe" I followed the instructions from...
1. Check that the path exists, i.e., you have a folder named: C:\Program Files\G7PS\VersaCheck 2002\_Update\ 2. Check that you have permissions to create a file there, e.g., create a simple dummy.txt file in this directory with notepad (you can delete the test file after that)
If (1) is the problem - create the necessary folder(s) if (2) is the problem - check the you run as administrator
May 15, 2011 | G7 Productivity Systems VersaCheck Home &...
I keep getting this error: Intel® Express Installer < The application failed to initialize successfully-(E0441203). Actually when installing the mother board drivers, there has been a power cut...
The failed install has messed Windows itself its integrated installer has been corrupted.
The easiest way to fix that is to reinstall, otherwise you will gonna have to manually delete all partially installed drivers, clean the registry and perform a Repair install.
Sep 24, 2010 | Intel Computers & Internet
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Random disconnects
Your problem is on the Cable companies side, there is nothing you can do besides making them come out to fix it. Be warned that some ISPs are known to play the blame game and pin it all on you...I used to work for Comcast and seen this happen regularly.
In short, you are looking for a connection problem in the lines around/in your house.
The long version:
The cable wires that run around the neighborhood are the main lines. Every few houses there is what is called a "tap". The tap is a little box with a few ports to connect a regular sized cable to it(the same cable you see inside your house). Fromt he tap the cable goes to your house and "should" be connected to what is called a "ground block". A ground block should have a wire going from it to some type of ground. This is to prevent an electrical shock traveling through the lines into your house and frying anything connected to it. From the ground block it should then go into a "splitter". The splitter has 1 input port for a cable line to connect to and has anywhere from 2-10 output ports. If there are unused output ports, they should be capped off to reduce signal bleeding/loss/interference.
Okay, now the fun part. From the ground block, the next step in your line should be a 2 port splitter. So it should have a cable going into it and 2 coming out. One of the 2 coming out of it should be going "directly" to your modem. If the setup is any different than I just described, your house was wired wrong and could be the culprit to your internet problem.
There is also a possibility that your "tap" is bad, I have seen it more than a few times. A low level tech can fix this.
Also, there are boxes every so often on the main lines that run on the telephone lines. They can be misconfigured and also create internet problems. These will require a higher level technician to fix.
Next possibility is that your modem itself is bad, when you schedual a trouble shooting call with your ISP, ask them to bring an extra modem with them.
Almost forgot an important one, where the cable "screws" into any port on the tap, ground block, splitter or modem...it is not snug tight and you are not getting a full signal. This is a very very very common problem. The endings that screw into things, they are called "F-Connectors" and do periodically require to be replaced.
The tech that comes out to fix your problem, if they do not have a wave length meter on them...they do not have the proper tools to diagnose your problem. An official tech of your ISP will almost always have one on him, it is the contractors that usually do not. Ask for a real tech and not a contractor to show up.
Keep calling when you experience problems. Each time you call, ask for money to be taken off your bill for your troubles. If the person on the phone says they can not do that, ask for a supervisor.
Hope this helps.
Feb 02, 2010 | Arris SURFboard® SB5101 Cable Modem
I am getting "The application failed to initialize properly"
you will need to reinstall the yahoo messanger application.the application has gone corrupt
Nov 29, 2009 | Yahoo Messenger
VERSACHECK
You need the following file from the G7 web site. http://www.versacheck.com/update/2002/vcheck7_0_9_1.exe .Follow instructions carefully and Versacheck 2002 will run.
Feb 15, 2008 | G7 Productivity Systems VersaCheck Home &...
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
G7 Productivity Systems Versacheck Gold 2008  Full Version for PC  Logo
739 people viewed this question
Top G7 Productivity Systems Computers & Internet Experts
Jax Planet
Jax Planet
Terry Hair
Are you a G7 Productivity Systems Computer and Internet Expert? Answer questions, earn points and help others
