Question about Asko Washing Machines
Unable to open door
Machine did not rotate during wash or spin and now I cannot get door to open.
I suspect brushes in motor need replacing.
  • 32 Answers
Usually this type of problem is in the door switch. If you unplug it for an hour and try plugging it in, does the door open?
Posted on Sep 27, 2009
Zanussi turbodry wdt 1075 washing machine fills & drains but does not perform wash cycles or spin cycles drum does not rotate
Quite probably the motor brushes. Disconnect from mains. Tilt machine backwards as far as possible. On motor, disconnect wires to brushes. With a multimeter, check continuity between brush and any segment if the commutator. If open circuit, replacing the brushes should do the trick. Also visually examine the commutator for damage
Aug 17, 2014 | Zanussi Washing Machines
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
Machine won't spin
Hi, can you start the unit without any clothes in it, let it fill with water as usual and then observe if it tumbles in both directions during the wash cycle ? ( I don't mean the entire cycle, just long enough to insure it rotates in both direction ). Then turn it to drain and insure it drains completely, observe the spin cycle if you can and report if it only spins in one direction slowly. This will go a long way in diagnosing your Asko washer. Let me know what you find. If it only goes one way, the motor needs new brushes and possibly a complete motor if the armiture is damaged. Good luck. Macmarkus :)
Apr 26, 2010 | Asko W6021 Front Load Washer
Washing machine not spinning fast enough and
Check motor capacitors. Check freeness of the drum rotation, if you suspect clutch
Apr 02, 2010 | Washing Machines
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Error F 04
im not up to speed with the codes. BUT if you are able to open the door this suggests the bulk of the water has pumped away, so I suspect motor or belt problems. Can you hear the motor spinning when it should be? ie on spin cycle. If not suspect carbon brushes in motor, or even a broken/burned out wire to motor. Replace belt if broken
Oct 15, 2007 | Hotpoint Aquarius WD640 Front Load...
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
