Question about Garden
Hello,I have a briggs 13.5hp I/C ohv single cylinder engine I just rebuilt.when I go to start it up I have to choke it to get it to start.while its running it back fires threw the exhaust and carb.Also the govener hunts.If I choke it half way it will idle high and run without backfire or hunting.I'v tried adjusting the valves from .004 to .006 and cleaned and inspected the carb,adjusted the govener and inspected spark plug gap.I need help.Can someone help me?
  • 3 more comments
  • ronwiswell Sep 28, 2009
    yes,but nothing happens.still runs the same.
  • Chuck
    Chuck May 11, 2010
    Did you set your timing marks correctly on the camshaft and crankshaft ?
  • Joe R. Downs Jr. May 11, 2010
    Have you tried adjusting the fuel/air mix screw?
  • Anonymous Mar 30, 2014
    engine will not start I have fuel going all the way to the carb, when I try to start it back fires threw the carb real bad.
    will not start back fires threw carb
  • 472 Answers
Sounds like you you have bad gas and a air leak
Posted on Oct 01, 2009
What briggs valve gap lt1000?
Briggs opposed twin cylinders don't have valve gap. Single Cylinder OHV & V- Twin OHV do.
Jul 13, 2014 | Briggs & Stratton Garden
Briggsload Stratton 14.5 HP single cylinder OHV gasoline engine has episodes of severe smoking when
When what if you are saying when starting..after sitting..the oil from your overhead valves are seeping into the heads through open valves..when not running..most likely bad valve stem seals...
Apr 12, 2014 | Briggs & Stratton Garden
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a 25 hp ohv briggs and stratton, it will not run without having to choke it some
Try increasing the idol by turning the idle screw up.If that doesn't work the carburetor may need to be reset properly or it might need an overhaul.
Mar 09, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Smoking and loosing power
Blue smoke means engine worn or too much oil in sump.
Black smoke is caused by too much fuel being sucked into carburettor.
This can be caused by a dirty air filter, choke being left on after engine is started or fault in choke system if automatic choke fitted.
Feb 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Oil in crankcase
that's where the oil is supposed to be. a single cylinder engine takes 12 ounces of 30 W oil
Aug 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
18 HP Briggs and Stratton OHV Model 31M777 runs rough
Have you checked the choke? Sounds like it might be stuck closed or partly closed.
Jun 20, 2009 | Garden
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
