Question about Goldstar MV-1526 Microwave Oven
HI , WE HAVE A MICROWAVE MODEL3 MV152W. THE TURNE TABLE IS NOT WORKING,ONE PICE IS MISSING(I BELIVE THERE SHOULD BE A SHAFT COMING OUT FROM THE BASE TO TURNE THE TABLE) CAN I ORDER ONE.
  • 909 Answers
Yes you can but when ordering, quote the model of your microwave to get the correct one. (There are many types available, but only one correct one.)
Posted on Sep 27, 2009
Testimonial: "thanks"
How to clean liquid under round grate oven base?
tip it toward the back and be prepared to wipe up a big mess
Apr 12, 2015 | GE Advantium 120 Convection/Microwave Oven
My Whirlpool Whirlpool microwave table does not turn
Usually indicates a bad turntable motor (accessable from the bottom of the microwave oven), but sometimes (in some cases) the turntable shaft coupler (which is made out of plastic), splits or cracks, so the motor turns, and the shaft slips inside the coupler.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 08, 2014 | Microwave Ovens
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | KitchenAid Microwave Convection Oven
My ge microwave spacemaker has a rattling sound when in use. disappears when turntable is turned off.
You may have a turn table motor that is beginning to fail. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can purchase replacement parts at the any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your model number and let me know. I hope this helps you.
NOTE: You may consider replacing the turn table coupler (also known as a turn table shaft) as well. This is the small plastic shaft that connects to the turn table motor and is the visible piece inside the oven where the glass tray sits. The coupler will simply pull straight up and come off the motor shaft. They can wear out and begin to slip on the motor shaft.
Jan 27, 2010 | GE JVM1640 Microwave Oven
Plastic peice that fits under plate inside micowave that makes it rotate
If the model number you have this question listed under is correct, there are two possible parts based on your question. There is the carousel ring, that turns the glass tray, and there is the small plastic coupler that the center of the glass tray is supported by. The part numbers are as follows:
Carousel ring - WB06X10513
Coupler - WB06X10564
You can view and excellent exploded view diagram of this microwave at pcappliancerepair.com. The parts I mention are listed under Diagram 1151005 as items 84 and 101 respectively.
To replace the coupler, you simply remove the glass tray and gently pry straight up. The coupler will pull off of the turn table motor shaft. Insert the new coupler and press on to the shaft.
If this is not the correct model number, please post back with your correct information so that I may be able to provide you with better assistance. I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Missing the plastic ring under the turn table
I'm not 100% sure but 95 that it doesn't have a roller.
Here's the replacement...
https://www.amazon.com/Replacement-Danby-DMW753W-Microwave-Glass/dp/B00YOPH5F0
or ck here too...
www.repairclinic.com
Appliancepartspros.com
All show it without roller.
here's the manual....
https://www.manualslib.com/products/Danby-Designer-Dmw1048ss-193717.html
Best to you.
Feb 02, 2018 | Danby DMW1146SS Microwave Oven
Belling microwave
Turn table motor open circuit/drive shaft damaged
Oct 18, 2008 | Belling Microwave Ovens
1990 Sharp Carousel II over microwave / vent hood
Sharp calls that the turntable coupler when it's a separate part.
If it's part of the the part with three legs, that is called the turntable support.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
If yours is model R1610, we actually have that full service manual on our site at http://www.microwavedisplay.com/r1610_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 02, 2008 | Sharp R-1610 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Goldstar MV-1526 Microwave Oven Logo
163 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
