Question about Garden
I installed new solenoid but know keeps blowing 15 amp fuse 2004 murray riding mower the same time this happened i found gas in my oil
    Problem Solver:
  • 16 Answers
Replace carburetor
Posted on Oct 02, 2009
I am looking for a parts and repair manual for a 2004 model #385016X78A Murray ride on mower.
Murray went out of business and was bought out by new outfit. Do not know if new Murray (kept the name) manufacturer will support the older products produced previously. You can always check and cross your fingers.
Sep 29, 2016 | Murray Garden
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
How do I fix my Murray riding lawn mower? The motor will not fire;
coil,safety switches,ignition switch,fuse,connected wrong,,,choose 1 to eliminate then go to the next,etc,,,etc,,
pull the black wire off of the coil,try to start,if it works,the safety switches(1 or 2 or 3 out of 3)are bad,seat,brake/clutch,deck switches,if not,then the coil is bad,pull the ign switch out,clean all contacts on back and plug back in
May 25, 2015 | Murray Garden
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
I have a wire pulled out of the 15 amp circuit breaker housing off of the solenoid on a 42" murray riding mower....can this be replaced and hoe difficult is it?
I believe from you description your referring to the 15 amp fuse. You can get a fuse holder at the local auto parts store along with a terminal end with a 5/16" hole and 1- **** connector. You will need an adjustable wrench to take the terminal loose on the solenoid and a pair of cheap wire pliers for the striping of the wires and crimping of the ends. Really pretty simple just make sure you unhook the negative terminal of the battery before doing any repairs to the electrical system. Let me know if this is enough detail for you.
Mar 23, 2011 | Garden
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray riding mower won't start
Sounds like a defective starter solenoid.
Jun 17, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
