Question about Canon PowerShot A590 IS Digital Camera
My flash is not working and when i go to take a picture, its not working very well. My camera is a canon powershot A590
poolseman
  • 206 Answers
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Posted on Sep 14, 2007
futureloginn
  • 734 Answers
SOURCE: Canon Powershot A550 flash will not work it just blinks on & off?
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Posted on Dec 04, 2008
SOURCE: Canon powershot A630 blinking flash graphic
You have to unscrew the left side of the camera (if you're looking at the back of the camera, the side that is right beside the flash). Then, at the very top, with a tiny screw driver, just gently tap the black flash compartment and it should work after that. I've had the flash problem twice in the past year and both times I got it to work again by taping on it. Hope it helps!
Posted on Jun 29, 2009
  • 11967 Answers
SOURCE: My Canon A590 is saying lens error restart camera.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 29, 2009
SOURCE: canon powershot A590 displayes lens error, restart camera.
I had this problem. Nothing was lodged between the body and lens, restarting multiple times did nothing, cleaning, torquing, twisting over several days - nothing.
So, figuring "what could it hurt?" I just smacked it on the heel of my hand a couple times. Now it works.
firm percussive maintenance saves the day once again.
Posted on Jan 19, 2010
I have a dead flash on my Canon A590. What do I do?
If you would like to replace the flash yourself, you can find a guide to taking it apart here: http://www.ifixit.com/Guide/Repair/Repairing-Canon-PowerShot-A590-IS-Flash-Assembly/3680/1
Otherwise a camera repair center could help.
Mar 06, 2011 | Canon PowerShot A590 IS Digital Camera
My flash is not working. the icon keeps flashing for a long time before taking the picture before it takes a picture. I've reset the settings and tried all the different modes and cannot get ii to...
I found this somewhere else and I was surprised that it worked. Reset to default settings. Press menu, arrow right to the tool menu. Arrow down to Reset All, arrow right to yes.
I had tried different batteries, even alkaline to get it to work thinking that my batteries were old and weren't charging the flash. I saw that someone had done the reset all to fix it. I did it and tried to take a picture, the icon flash twice and then the flash charged up and took the picture. I replaced the batteries to lithium and now it charges up right away. I hope that helps.
Dec 26, 2010 | Canon PowerShot A590 IS Digital Camera
Flash not working
Only you can make the executive decision if it would be worthwhile to fix the onboard flash.
You can send the camera into Canon and get an estimate on how much it would cost for the repair.
Hope this helps,
Andrew
Apr 13, 2010 | Canon PowerShot A590 IS Digital Camera
Canon powershot a590 IS lcd screen
I had this same problem. Once I got over about 1200 pictures, the screen just turned black, and the only setting that would work where I could see the lcd screen was the easy setting. I had read somewhere that this was due to the amount of pictures the camera had "counted", even if those pictures had been downloaded and erased from the camera. So I decided to reset the camera. Go to the tools list in the menu, scroll down to "reset all", and when it prompts if you want to "reset settings to default" click ok. This worked for me, and all of my settings - sunset, landscape, etc. - parameters in any of the settings (shutter speed, lighting, etc.) those will have to be reset.
Nov 05, 2009 | Canon PowerShot A590 IS Digital Camera
I have a canon powershot a590 IS. I uploaded
CCD FAILURE !
But good news is it is manufac fault and CANON will do it FREE just call them even if u are out of warranty , they have issued service advisory for such faults just call them in ur region and they will send a postage paid envelope for u
Pls rate me WELL !
See Advisory just call them !
May 18, 2009 | Canon PowerShot A590 IS Digital Camera
Canon A590 takes only black images
According to the manual, you can reset the settings per directions on page 147 of the 211 page manual.
Press the Menu button
Scroll left or right to get to the Tools menu
Use the up or down arrows to select [Reset All]
Press the Func Set button
Feb 07, 2009 | Canon PowerShot A590 IS Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
