Question about LG Shine CU720 Cellular Phone
How do i change the light color on the keypad? the color is white and i would like it to be a different color can i do that?
Faulty w850i
Are you sure you have flashed it correctly? I had a white screen problem and flashing fixed it. Make sure both your main and fs firmwares are the same type eg W850_R1ED001_FS_VFE_LIVE_1_RED52
W850_R1ED001_MAIN_GENERIC_CY_RED52
and your custom pack can be any w850
Dec 03, 2008 | Sony Ericsson W850i Cellular Phone
Accurate color
Digital cameras rely on "white balance" to control total overall color accuracy as processed for the final image. Colors are greatly affected by light. For example, look at any wall in your home or office and you can easily see that shadows will make the color of the wall appear to be different shades. Sunlight has a very different effect on colors than incandescent light or florescent lights. Digital cameras start with white (the absence of color) to measure the effect of light and adjust the metering (measurement and accuracy) of all the other colors. Of course, white in a poorly lit room may appear gray or even yellow to some digital cameras. So how can you get accurate color? 1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Accurate color
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
White Balance
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, One-touch, and White balance compensation.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder/monitor. You can choose mode from Auto, Preset and One-touch.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
White Balance
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
White Balance
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, and One-touch.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
LG Shine CU720 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
