My new canon pixma mp630 prints to the left of the page. When i did the printer head alignment, the print area - rather than being centred - is way to the left. How can i reset it to centre printing on the page?
Canon MX870 print alignment. Only occurs
Reinstall the printer driver. Sounds like it is corrupted.
May 09, 2017 | Canon PIXMA MX870 Wireless Office...
How to replace print head in Canon PIXMA MP630?
Most cannon printers have same print head, and replacing them is relatively easy... First open up printer cover to get to the print head. If you have manual for your cannon model, see in manual how to change color cartridges. When you get print head in position for changing cartridges, take out that CMYK cartridges one by one. After that, you will notice there is some kind of a lever on one side of print head. Try to pull that lever up, and it should release your print head. Now you can take it out, and put a new one if you have it.
Mar 06, 2011 | Canon Office Equipment & Supplies
My Canon Pixma MP480 All-In-One InkJet Printer is printing half the page, words are cut off.
Hi Good day!! Try to try the head cleaning and alignment
1. Click "Start"
2. Click "setting"
3. Click "Printer and faxes"
4. right click your printer and then properties
5. go to printing preferences"
6. Click "Maintenance"
7. Choose Head cleaning.. after that you can align it.. by clicking "Align button.
if still haf page, clean it again and align...
Hope it works!! thx
Oct 12, 2010 | Canon Pixma MP480 All-In-One InkJet...
Printing problem with my canon pixma mp630
Run the alignment test page from the software on your computer and check and adjust the alignment.
Dec 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Canon Pixma MP630 not printing all colours
Colour not printing. Check vent hole on cartridge not blocked by glue or bit of the orange tape, cleared mine with knife now works fine
Feb 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Partial Printing
Please go to this page and type in alignment if you are on Mac. The instructions below are for Windows OS.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11642
Performing the Print Head Alignment - iP1600 (Windows)
1. First, load a sheet of A4 or Letter size plain paper in the Auto Sheet Feeder and then open the Properties window.
For Windows XP Home Edition
Click/Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000/Me/98
Click/Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
2. Select the 'Maintenance' tab.
3. Click the 'Print Head Alignment' button.
4. Click 'OK'. The pattern will be printed.
5. After the pattern is printed, click 'Yes'.
Align the Print Head
1. Look at the printout. From the patterns, select the most even and least irregular patterns.
2. Enter the numbers.
3. Click 'OK'.
The Canon page contains graphics, and can be reached in the same fashion as indicated above if you need those.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
May 23, 2008 | Canon PIXMA iP1600 Printer
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Does not print on paper
Experienced the same problem a few months back with my new MP600 .. had to take it to an authorised repair centre where they replaced the print head .. all good since
Daniel
Sydney
Nov 01, 2007 | Canon PIXMA MP600 all-In-One InkJet...
118 people viewed this question
k24674
jasbo
jasbo
