Question about Garden
How many different types of starter motors are there to suit a 12 hp ride on mower
  • Chuck
    Chuck May 11, 2010
    What is the Model and Type number off the engine??
    Scholar:
  • 43 Answers
First you have to have a flywheel that will support a starter. It must have a toothed flywheel. Second, the brand of motor. Briggs & Stratton, Tucumseh, Kohler, Onan, Wisconsin, ect. Was it originally electric start? Has battery tray, key switch, ect? You will need the Serial Number, Model Number which is on the "blower housing", or the recoil start housing on the top of the motor to replace with the correct starter. You probably can find one at any small engine repair shop, maybe a lower cost used starter. But you need the information above to obtain that. Model #, Serial #, Make, ect. If this mower wasn't electric start originally, this will be a major change. Flywheel, starter, wiring, battery, switch, and the like. Not for the faint of heart. It can be done, and has been, but will be difficult. If it is a Briggs and Stratton, you should find parts easy to access. And Tecumseh. And relatively economic.
Posted on Sep 27, 2009
What is starter
Posted on Jan 01, 2013
Model 170 with a Kawasaki 14 hp engine. Why doesn't anything happen when I turn the key?
This is a 12 volt system and the battery should have 12 1/2 volts. Motor running the voltage should be above 13 volts and below 14.5 volts. You will need a battery charge or jump start.
Mar 29, 2016 | John Deere Garden
Motor is locked up wii\ll not turn over
Have you checked battery voltage and amperage? Also check starter solenoid for 12 volts while trying to start. Starter could also be weak.
Jul 23, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
12 hp briggs backfires doesn't start
This could be a result of several different things, however the most common of these would be a sheered flywheel key. If this is the case it has throwed the motor out of time and is trying to fire while the exhaust valve is open causing the backfire and lack of compression to start. I hope this has helped.
Sep 30, 2013 | Simplicity "Citation 61"" 28-HP Briggs And...
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
How do you adjust the valves on 13.5 hp tecumseh mower engine
Type in( video how adjust valves 13.5hp tecumseh) in Goggle.
May 29, 2012 | Tecumseh 100% 12v Starter 35765 32468...
Was runnibg tractor, it suddenly cut off would not crank, put more gas in still no crank,, when turn key made a clicking noise , then a type of humming noise ,, battery is about two yrs old, got at...
Try jumping the battery with a car as long as the two are 12 volts.
If this starts the mower, it is the battery.
If the mower won't start with a jump, there is a different problem.
Mar 04, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Riding mower won't start
clean all your battery connections from battery to starter and selonoid connections and ground cable also where it connects to frame
May 23, 2010 | Garden
The starter will not crank over the compression stroke
You needv to check whatever the tractor uses for a decompresser,whether it be a lobe on the cam or the camshaft it's self.Sounds like it's not decommpressing during crank.You may need to just set the valves.
Oct 23, 2009 | Garden
Garden Logo
1,714 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
